Trailer Mover Build
/ Trailer Mover Build
I use this trailer mover weekly mostly with the BX. I moved a pretty long gooseneck horse trailer with it a while back.
I moved a stock trailer with it
and a deck over
I still don't have it painted yet. If things work out right I may get it painted next week.
/ Trailer Mover Build #22
Good looking trailer mover!
/ Trailer Mover Build #24
Nice paint work! That Vette is SHINY. :)
Thanks, I used a $8 Harbor freight gun to paint it. I have a decent Devilbis HVLP gun but it is too big to use for something small like this. I put pics of the Vette in the other thread.
I had been wanting to build an attachment for the trailer mover with a coupler on the end of it so I can use a tractor to push a dead vehicle in to the garage using trailer hitch. I got lucky and found this at a carshow/ swap meet last Friday. The coupler is rated for 20K. Everything was welded together all I had to do was drill the hole for it to fit the hitch.
I mostly drag stuff in with the BX and circle out but if sometimes another vehicle may be in the way so now I can pull them in close and then push them.
I pushed a truck today with it.
/ Trailer Mover Build #28
That's a good idea. Sure beats the way I have been doing it. (FEL and old tire against the bumper.)
Thanks. I used to drag a smaller vehicles in with the Cub Cadet. It probably would have pulled that truck since it was close to the door. For bigger vehicles I used to use a tire on the 8N bumper. Now I drag them all with the BX. This method makes it nice for me because it is not always possible to drive back out. I am also thinking about putting an anchor bolt/s in the floor then I can attach a snatch block to and hook a cable to a car, run the cable under the car, hook it to the tractor and drive away to pull it in.
2012 FORD F150 REGULAR CAB PICKUP TRUCK (A66091)
2012 FORD F150...
2012 MAGNUM TRAILER WATER TRAILER (A67714)
2012 MAGNUM...
2005 JOHN DEERE 310G BACKHOE (A65053)
2005 JOHN DEERE...
Unused 2023 Del Morino CS158M Agricultural Flail Mower Tractor Attachment (A66734)
Unused 2023 Del...
2022 Ford F-150 4x4 Crew Cab Pickup Truck (A66736)
2022 Ford F-150...
2014 GRADALL XL3300 II MOBILE EXCAVATOR (A65056)
2014 GRADALL...
