teejk
- Joined
- Mar 3, 2012
- Messages
- 1,791
- Location
- Merrillan, WI
- Tractor
- JD 2020, IH CC 1250, Ariens 926 Snowthrower
Probably addressed already but I'm lazy...when we built the house I also built a shop building 100' away. I had the well driller run 1" poly water pipe to the shop since the trenching guy was on site twidling his thumbs (I ran 100a electrictic service at the same time). I didn't have to worry about disturbing the driveway at a later time that way.
So the well into the house enters about 8' below grade. The pipe to the shop (on a shut-off valve from the pressure tank) also exits at about the same depth.
So now thinking about bringing water into the shop. I'm fine with everything other than that 3 or 4 feet of pipe that emerges from below the frost line before it enters the shop. It gets VERY cold here so that is a potential issue. Plus I do keep the shop heated when required but there might come a time where I don't want to.
Any thoughts will be welcomed.
