Receiver drop calculation
/ Receiver drop calculation #1
Eric_Phillips
Rochester, NY
FarmTrac 270DTC
I have a 2011 F150 and just bought a used 2-horse trailer. The top of the hole for the receiver on the truck sits at 19.5". The bottom of the hitch on the trailer when level is 13.25". The current receiver has a 2" drop. When I hook the trailer up with that receiver the truck sags ~3" to 16.75". A 6" drop seems huge and with no sag it would put the bottom of the trailer jack ~4" off the ground. A soon as the truck sags a little and I put horses in the trailer I think it will be dragging on the ground. I would feel better with a 3" drop. Is that ok for this setup?
/ Receiver drop calculation #2
Try loading your gear and horses with the 2" drop you have now. Then you can do some measurements to know for sure what amount of drop you are going to need. It's always better to be a hair high with the front of the trailer than too low (level is ideal).
/ Receiver drop calculation #3
I agree, load up completely with current drawbar and then measure the difference needed to bring closer to level.
I went with a 4" drop for my new truck based on measuring difference in receiver height from old tow vehicle (which had 2" drop"). I noticed that for the heavier-rated drawbars (mine is 10,000#) the selection is limited. Did not see any 3" in that rating. So you may need to go with the closest available option.
Just so I understand your suggestions completely. Load the trailer and reconfirm height when level not connected to truck. Connect to truck and determine how much drop I need to reach level.
/ Receiver drop calculation #5
Sounds like you are on the right track.
/ Receiver drop calculation #6
If you need a 3" drop you can always use a 1" riser ball on a 4" drop hitch and be right on.
/ Receiver drop calculation #7
You might look at a place like etrailer.com for adjustable drawbars.
/ Receiver drop calculation #8
$60
on the plus side if you have different trailers you can adjust the height for them, and pulll the 2 pins and pull the ball off while keeping the shank in the reciver if you like something back there for people to run into instead of your plastic bumper.
2008 Case CX240B Hydraulic Excavator (A64194)
2008 Case CX240B...
2022 EZ-GO ELITE...
2005 Acura RSX Coupe (A64557)
2005 Acura RSX...
2021 Redirective Crash Cushion Guardrail (A64556)
2021 Redirective...
2020 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A67148)
2020 KENWORTH T680...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
