How do you fuel your tractor (logistics, not finding the cap to the tank)?
   / How do you fuel your tractor (logistics, not finding the cap to the tank)? #191
Haven't had a need for an auto shutoff. I turn the pump on and stand on the 3pt.
   / How do you fuel your tractor (logistics, not finding the cap to the tank)? #192
   / How do you fuel your tractor (logistics, not finding the cap to the tank)? #193
Here's how I fuel mine. A 14 gallon Flo 'N Go.
   / How do you fuel your tractor (logistics, not finding the cap to the tank)? #194
It is fascinating to see all the different ways people resolve this odd difficulty.
But a number of the responses lead me to a different, but related, question. Several respondents have said they use 55 gallon drums, or 100 gallon tanks that they fill in various ways. My question is, how long does diesel fuel last? One is always told to use "fresh gasoline" in your lawn mower or chain saw; and that you should discard gasoline not used over the winter. I also understand that diesel fuel used for trucks, etc., which one buys at a gas station is formulated differently for different seasons. If that's true, one imagines that fuel bought in the spring is probably not optimal for snow plowing. Note everything I have stated here is hearsay; I'd love to know the real situation.
dan
   / How do you fuel your tractor (logistics, not finding the cap to the tank)? #195
dan
Diesel fuel itself lasts a long long time (years if not decades). But you must make sure it does not get water in it or it will grow algae. (diesel bugs). You can always put in some of your favorite diesel additive for the winter. Not so gasoline. Expecially gasoline with ethanol in it..
   / How do you fuel your tractor (logistics, not finding the cap to the tank)? #196
Thanks to a poster on another forum, I found this:
No Spill Fuel Cans
This is the greatest thing since the invention of lubricated condoms.
My tractor has the fuel filler on the hood. This makes filling the tractor much easier, and it doesn't spill a single drop. You can just lay it down on its side and push the button.
You're the first person I've heard that liked the new no-spill style nozzles. Maybe it's political with them (EPA, CARB-compliant), or maybe it was a different less quality nozzle. I'm going to need some replacement cans soon so I'll give them a second look.
   / How do you fuel your tractor (logistics, not finding the cap to the tank)? #198
I love the no spill can for my small power equipment... finger tip control allows me to fill quickly without spilling a drop.
Bought my first one at the Honda Dealer.
I hate with a passion the other versions of the CARB/EPA cans that self destruct by themselves!
   / How do you fuel your tractor (logistics, not finding the cap to the tank)? #199
Not so with bio diesel....it will start to grow pretty quick.
   / How do you fuel your tractor (logistics, not finding the cap to the tank)? #200
While my tractor is easier to fuel since its on the fender; I'll still add in what I use. I just got the tractor and needed some diesel cans and hate all the CARB compliant ones. I did some searching and came across racing fuel cans. Since they are not "designed for transportation" they don't require the auto vent and have a real open vent. The ones I bought came in tons of colors (got yellow) and with a long filler hose that I can get in place before fuel flows. The caps on them are also very heavy duty. They were a little pricey, but well worth it. I dump all 5 gallons in a minute or two.
JOHN DEERE ROW MARKERS - SET OF STACK FOLD 12 ROW 30 INCH ROW MARKERS (A55315)
JOHN DEERE ROW...
LOT: Receiver Hitches, 1/2 Ton Sheet Clamp, Pipe Threader (A59076)
LOT: Receiver...
2025 Wolverine MAD-12-12D Auger Mini Skid Steer Attachment (A56857)
2025 Wolverine...
Tube Broom 8, 5/8 x 58 Poly 26" (A59076)
Tube Broom 8, 5/8...
Kubota M4700 4WD 51HP Utility Loader Tractor (A56857)
Kubota M4700 4WD...
2023 Bobcat T770 (A53317)
2023 Bobcat T770...
