Front Axle Pivot Lock
/ Front Axle Pivot Lock #1
Bengineer
Member
NC
Kubota L2501
This recent thread Stepped off with snowmobile on loader, almost tipped over got me wondering why tractors with loaders don't have a pivot lock to minimize the tip factor when using the loader. As it is, the tractor has the stability of a tractor with tricycle front gear. With a lock engaged to prevent the front axle from pivoting, the tipping force would be spread out to the width of the front wheels. I googled around a bit on TBN, but didn't get any hits. I'm thinking this is either a brilliant idea or a stupid question! :)
/ Front Axle Pivot Lock #2
The tractor would constantly be lifting front tires off of the ground on anything that isn't perfectly level.
/ Front Axle Pivot Lock #3
The pivot is the only means to keep all 4 tires planted on uneven ground. It has no suspension like a car or truck. Just be sure the back end weighs more than the front.
/ Front Axle Pivot Lock #4
How many degrees or freedom in the Lombardini or Goldoni articulateds? They seem to work well.
Yes - I get why there's a pivot for normal use. I'm thinking of something you'd engage for, say lifting a near capacity load high, as onto a truck or similar. Just thinking out loud - rough terrain forklifts & telehandlers have a hydraulic leveler so the lift can be plumb on the uneven ground.
Kubota V3600-T-E2 Turbo Diesel Engine - 3.6L - 84 HP - 2018 - Tier 2 - Pump Takeout (A63689)
Kubota V3600-T-E2...
Kuhn FC400RG (A60462)
Bomag Roller (A63689)
iDrive TDS-2010H...
New Landhonor Skid Steer Utility Hitch Adapter (A62679)
New Landhonor Skid...
2014 CATERPILLAR D5K2 LGP CRAWLER DOZER (A65053)
2014 CATERPILLAR...
