L130 PTO not working
/ L130 PTO not working #1
hunting404
SE Wisconsin
Kioti CK20, John Deere L130
1. Yesterday while cutting the grass the mower deck stopped working. I disengaged the PTO knob then reengaged it, nothing. The mower deck would
not work.
2. After the mower deck stopped working I stood up from the seat of the mower and the enging kept running. Isn't the enging supposed to shut down
if you get off the seat?
I was owndering if the safety switch under the seat could be the problem. Any help will be greatly appreciated. Thank you
Jim
/ L130 PTO not working #2
I have several mowers where the seat safety switch only operates with the PTO engaged...............I'm working a PTO problem on a restored "antique" JD 314 as we speak -- new PTO switch, new wiring harness, mower deck blades move easily with one hand, PTO works as it should on a 12V bench check and still the thing dies when it engages............three mechanics have looked at it and all seem puzzled
/ L130 PTO not working #3
not work.
Jim
I agree --- the seat switch should only kill the engine if the PTO is engaged. So you know that the tractor thinks the PTO is disengaged. Have you looked at the wiring?? Everything in tact??? Measured the voltage at the PTO plug with/without the switch engaged?? Do you have any power at that point??
/ L130 PTO not working #4
It might be that the belt slipped or stretched to the point that it does not engage the spindles on the mower deck.
2019 ISUZU NPR 4X2 S/A 20FT BOX TRUCK (A59910)
2019 ISUZU NPR 4X2...
Four (4) R207782 Rear Wheel Weights (A63116)
Four (4) R207782...
207281 (A52708)
207281 (A52708)
2017 Ford F-150 Pickup Truck (A61573)
2017 Ford F-150...
2010 Ford F750 Single Axle Dump (A62613)
2010 Ford F750...
Bush Hog 3008 Pull Type Rotary Cutter (A64047)
Bush Hog 3008 Pull...
