Speed reducer
/ Speed reducer #1
rasorbackq
Springfield Nova Scotia Canada
Branson 4720
Looking at a project where an electric motor and a speed reducer will be required.
My question is can I install the 10:1 speed reducer with the out put shaft facing straight up. This will lay the breather on the side. Or what about extending the air breather to the top ?
/ Speed reducer #2
Is it a right angle speed reducer or inline? Many speed reducers I've seen have multiple plugs to fill/drain/install breathers in different places for different orientations. Either way you should be able to find literature for whichever you are using that will give recommendations.
/ Speed reducer
I need the 1" pointing straight up but that will leave the breather at the side mid point.
Or this one that will leave the breather on the bottom.
Have not seen either of these to see if the breather can be repositioned.
/ Speed reducer #4
Plumb an elbow into the breather hole with a section of straight pipe at the other end, running up, vertically, and extending above the g-box; then add the breather to the end of that?
/ Speed reducer #5
I did something similar. I had to tap a new hole for the breather. It has to be above the oil level, preferably on the top, or the oil will leak out. If the worm is turning at motor speed it should throw enough oil to lubricate the bearing which will be above the oil level if the shaft is facing up.
/ Speed reducer
I used a right angle gear reducer with a C face for my chicken plucker and it has worked well now for years
Surplus Center
I think this is the one I used for mine,
if not the model it looks the same in construction,
10:1 RA GEAR REDUCER 0.77 HP 56C RIGHT OUTPUT
picture of the plucker in the web page, How to Butcher a Chicken, Part 1: Preparing Your Work Space; Killing, Scalding and Plucking Chickens
Would be nice to find a C face setup . I am building a plucker also. I have a belt drive now but just sold it . I wanted to build one with a chain drive or a PTO then I seen a reducer and started to think.
Does yours have a bearing on the shaft for the spinner?
I was going to build a Whiz bang style again buts yours looks light .
/ Speed reducer #11
yes it requires a C faced motor, some motors are combination motors, in that they have a "c face" and a solid base as well,
they are used on direct coupled items, pumps, gear boxes, and other items that would benefit from a direct coupling,
note: the C face is not one size fits all, it depends on the motor frame size, 42, 48, 56, 142,182, and so on, so make sure
your matched up for compatibility,
also motor RPM fro gear box,
double check shaft types as well, I have seen some pumps with application special shafts, (more important if your using a old pump motor),
http://www.grainger.com/tps/motors_nema_motor_dimensional_chart.pdf
/ Speed reducer
If I can find a C face motor and reducer for a fair $$ I may go that route but as of now will be using flex joint couplers . My dealer wants $500 for the reducer so that's not going to happen.
Might be more out there but not sure where to look. Your place Surplus center will cost a large fortune to get the stuff to Canada.
Our cheap place is called Princess Auto . They can only stock so many items and we have to made due.
/ Speed reducer #13
this place says sales to Canada look at there phone number.
right angle gearbox/gear reducers/gear reduction boxes/worm gear reducers/worm gear box/Mechanical Power Transmission
I am sure there are locations in Canada that do sell them you may need to do some web searching, at least now you have the internet, and things are much more available than pre internet,
I live in a very rural section of the US, and know some about trying to find things, and limited access, to parts and materials, and some times you have to pay some postage. I have bought from Canada and yes have had to pay extra to import it,
Also do not forget eBay and Craig's list type places, other avenues,
/ Speed reducer
So this reducer
This is the manual for it.
What does the vent direction info mean??
Install the vent plug according to the following::
1 Vent plug to be installed at the uppermost position.
2 For all mounting positions where the vent plug is located in a horizontal plane , the vent plug must pointed upwards.
3 For all mounting positions where the vented hole is located in a vertical plane. the vent plug must be pointed toward the center .
Questions?
What is the vert and *** plane mean and where is pointing toward the center of the housing?????.
/ Speed reducer
After reading the manual the output and input shafts can be removed to the other side so it appears the the output shaft should be able to be moved from th8494072.jpge bottom to the top of this one. I did order one of these today.
2017 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A67148)
2017 FREIGHTLINER...
2005 JOHN DEERE 310G BACKHOE (A65053)
2005 JOHN DEERE...
20 FOOT SHIPPING CONTAINER WITH CONTENTS (A68842)
20 FOOT SHIPPING...
Kaufman 47ft. Gooseneck Tri Axle Car Hauler Trailer (A66736)
Kaufman 47ft...
2020 FORD F-350 (A67714)
2020 FORD F-350...
PORTA POTTY (A67714)
