MMM discharge flap - ideas to hold it up while in shed
   / MMM discharge flap - ideas to hold it up while in shed #1
SteveNH
Member
Southern NH
Kubota BX25, BX1870-1
Hi,
I am taking delivery of my second BX tomorrow, a BX1870-1 with a 48" MMM and front mount snow blower. I have an overhead door to my shed that is 6' wide x 7' high. I would like to favor one side to leave as much room on the other since my shed is only 8' wide x 12' deep. Is there a good way to keep the discharge flap up? I figure this will buy me a few inches on one side or prevent me from tripping over it on the other. Can I drill a small hole in it and use a bungee cord or just remove it? It is the fine cut deck. Not sure what others have done. I think my shed will hold the weight of the tractor, find out I guess.
I currently have a BX-25 with a 60" MMM and to be honest I guess I am getting lazier as I get older and didn't want to remove the FEL when I needed to mow and I figured it was just a matter of time before I hit something with it. I also have a few 3pt. implements that I figure the smaller BX can run. I'd like to keep the BX-25 set up with the FEL and BH on.
I'll have to report back in the winter about the snow blower, I have the 60" blade now and it worked OK but I wish I got the snow blower instead after having it a few years. After reading up on it and seeing how happy people have been with it I am hoping I will not be disappointed.
Thanks.
   / MMM discharge flap - ideas to hold it up while in shed #2
Hole in flap, bungee cord to mower, done.
   / MMM discharge flap - ideas to hold it up while in shed #4
Don't drill a hole in the deflector. I lift the deflector and stick a short piece of 2 x 4 (about 6 inches long) in the notch at the base. Works great and easier than a cord.
   / MMM discharge flap - ideas to hold it up while in shed #6
Don't do the above, the last thing you need is a 2x4 piece coming loose and getting caught up in the mower and getting tossed at high velocity.......
   / MMM discharge flap - ideas to hold it up while in shed #7
Umm, it's only for storage. The deflector shouldn't be raised when mowing.
   / MMM discharge flap - ideas to hold it up while in shed #8
A bungee cord may work without having to drill a hole in it. Or a piece of rope
   / MMM discharge flap - ideas to hold it up while in shed #9
Bungees are your friend! Use them early and often! :D
   / MMM discharge flap - ideas to hold it up while in shed #10
I originally went the drilled hole/bungee route and it worked fine. When I added the Cyclone Rake, it changed the two mounting bolts to studs. So now my discharge flap is held on by two large knurled knobs and I just take it off completely.
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
Club Car Carryall Electric Utility Cart (A55851)
Club Car Carryall...
2015 JOHN DEERE 35G EXCAVATOR (A52707)
2015 JOHN DEERE...
2020 CATERPILLAR 246D3 SKID STEER (A60429)
2020 CATERPILLAR...
2013 BMW 328i Sedan (A55853)
2013 BMW 328i...
DECORATIVE METAL GATE (A58214)
DECORATIVE METAL...
