RDrancher's Photo Thread
/ RDrancher's Photo Thread
Here's a few from a grading, culvert and driveway job last week. My mission...get it done with no imported dirt. And in a first for me, the homeowner will be pouring the concrete culvert ends himself.
/ RDrancher's Photo Thread #544
Assuming the topsoil gets put back (on the top) once you get grade, si?
The black clay in this area is pretty fertile down to about 8". It's a real expansive and a pita to grade, which is why lime is mixed in on commercial jobs where importing good dirt would be too expensive. If you cut it right to grade and run over it with a compactor, it's full of lumps and bumps. For yards and such I cut it down about 4'-6" below my final grade, pile it, mix it, then spread it back out heavy and cut it one time.
Any decent soil without organic in it gets stacked and used to profile the driveway.
I think that one will cost more than just one kidney. Maybe a lung and an arm, but he is your son and he wants it. Come on, daddy.:rolleyes:
Lucky for me...my favorite word is NO. Ask any of my kids and they'll verify. :laughing:
I've been subbing out all of the brush hogging jobs to my father in law for over two years. He has his own cutter now, but had been using mine. Yesterday I took my cutter out to do a couple of fields, old overgrown building pads and a few slopes for a long-term project I'm working on. Before taking off in the morning I decided to sharpen the blades and basically check out the cutter. I found and welded...a broken tailwheel brace and a large crack running from one blade bolt along the stump jumper. I'm glad he has his own BH now. :rolleyes:
I picked up the TR today.
Here's what a $5400 repair looks like.
/ RDrancher's Photo Thread #549
Ouch that hurts
Ouch that hurts
Yes it does, but it could've been worse. It pays to shop around...and country boys got your back. Two ASCO dealerships, one in Euless and one in Sherman. The estimate from Euless...$7k+. From Sherman...$5.7k. Sherman came in $300 under their estimate and threw in a few freebees including the latest joystick software update and sleeving the hydraulic hoses that blew. The machine was ready to pickup the same day the drivemotor came in too. They also provided a cab equipped rental for $275 a day. They've earned my business, that's for sure.
I'm hanging out around the house today, waiting for my step son's graduation ceremony. I found out that the school is putting on a lockdown party tonight. Every senior that attends gets $150! Pretty good idea though.
Man how things have changed. I graduated forty years ago and I still have the boot-mark on my backside from the kick out of the door!
/ RDrancher's Photo Thread #552
A couple of years back I made a $30,000.00 purchase of equipment in Stephenville. I saved $2,500-$3,000.00 on the package deal. One of the metroplex dealerships did not believe I had a better price, I guess. The next time I asked for a quote, they got serious on giving the best price. It pays to shop around for the best deal and price.
/ RDrancher's Photo Thread #553
:thumbsup:
Expletives have been modified or removed for your protection.
Unloaded my CASE TR320 from the trailer after the drivemotor/hydraulic hose repair, hooked up the bucket and parked it last week. It's been sitting there ever since. The total cost for the repair including the service tech call and towing of the dead machine... a shade over $7k.
This afternoon I walk out to the shop and hear the hydraulic cooling fan on the engine lid of my CASE TR320 CTL running. Since it rained last night, I thought that maybe the connector at the fan motor had gotten wet. When I opened the cab door I found the HVAC motor running and smelled burning electrical. At that moment smoke started pouring from behind the cup holder! I grabbed my fire extinguisher from the shop and shot it in there and removed the cup holder panel. The smoke was coming from the front (accessory) fuse/relay distribution block. When I removed the cover flames started coming out of the distribution block!
While I'm trying to pull out the burning relays, my wife's grandfather was trying to get the positive battery cable unhooked. After burning the heck out of my fingers removing the relays and dosing the area with fire extinguisher contents, he gets the battery disconnected and I get the fire under control.
#1 My fuse blocks are both mounted upside down, so it took me awhile to figure out which relays had fried. Turns out it was the EH (electric/hydraulic) Control Module relay and Option Relay. In the upside down configuration, the relays are mounted directly underneath the door seal.
#2 The accessory fuse box melted. The dealer tells me that to repair it they have to replace the entire harness, which includes removing the engine. $5000 minimum for the repair!!
I'm so ******* ****** off right now I could eat bricks! My lungs are full of fire extinguisher crud and smoke. If it was water that shorted something out, wouldn't a fuse blow? What about all of the machines without a cab? Those fuse boxes have no protection at all from the elements. Did the dealer pinch off wires somewhere when they had the cab up for two weeks? And just how do I prove that?
I'll call CASE once again to start an incident number, but them saying that they will help out is very unlikely. From my prior conversations with them they're about as helpful as **** on a ****.
This is a freaking 2012 machine with less than 850 hrs on it! One drivemotor/final and two electrical panel replacements under warranty...Now a blown hydraulic hose to the drivemotor, one more drivemotor/final drive replaced AND an electrical fire!
Sorry...had to vent.
I'm a one man show with a New Holland tractor and a CASE CTL, and I've been a faithful CNH customer since they became CNH. Ford before that. The expenses I've incurred to repair my CASE machine have already put my plans for building a new home for my family on hold. If they don't step up to the plate this time...they will have lost me as a customer forever. Whatever the outcome, I will document it right here.
Edited to add: The only reason I was near my CASE today is because I was going to take photos of the paint for another thread here I have here on TBN. If I hadn't gone out there right then...this could have been a major disaster for me and my family. The machine is parked less than 5 feet from my shop and less than 10 feet from our PROPANE TANK!
/ RDrancher's Photo Thread #557
My gosh it just keeps on raining on you.. Sure hope your Luck gets better. I hate Monday's.
/ RDrancher's Photo Thread #558
Man alive, what rotten luck. Hopefully you'll catch a break soon.
Thanks...Murphy's Law I guess! Ya gotta keep your sense of humor somehow...right? If CASE doesn't step up to the plate on this one...someone's is getting their arse kicked.
Thanks for the support Derek. I swear this crap is going to make an old man out of me...and I'm only 57!
275 GALLON POLY TOTE W/ CAGE (A64281)
275 GALLON POLY...
1999 Freightliner FL80 Altec A75 75ft. Bucket Truck (A61573)
1999 Freightliner...
2015 Ford Transit 350 4x4 Sewer Viewer Van (A61573)
2015 Ford Transit...
Bulk Lot - (3) Sticks HDPE Pipe - 24in x 40ft - Selling as One Lot (A63689)
Bulk Lot - (3)...
2016 FREIGHTLINER CASCADIA  125 6X4 T/A  DAY CAB TRUCK TRACTOR (A59912)
2016 FREIGHTLINER...
(6) 12" X 4' HUMIDITY CONTROLLER MILITARY AMMO BOX (A64281)
(6) 12" X 4'...
