2240 Clutch specs info
/ 2240 Clutch specs info #1
mtDanE
JD 2240, JD 1010u JD1010r, JD 420 l&g, JD 110 l&g
Good morning all,
I though my clutch was worn out, there was too much play in the petal. the gears would not stop turning when the clutch was engaged, but the linkage/rod from the pedal to the throwout bearing lever was tightened all the way. although the clutch was not slipping. so I split the tractor last night. the clutch looks good it is about 0.39" thick. the flywheel looks like it has been machined recently (before I bought the tractor). It looks like the levers on the pressure plate are adjustable. they are sitting 1.4" from the surface, when everything is bolted together. this is a single stage clutch by the way.
so my question are; what is the thickness of the clutch before it is considered worn out?
How do you adjust and set the levers (to what specs).
Thanks,
D.
/ 2240 Clutch specs info #2
Here's the spec's on a new clutch plate
/ 2240 Clutch specs info #4
For my 2030 There is a special guage/tool for setting the pressure plate fingers when bolted to the flywheel. Called JD227. 2240 may use the same or similar tool. Might be worth having a dealer do this adjustment, or see if they will loan/rent you the tool.
/ 2240 Clutch specs info #5
too much play in the petal...........must be 40mm/11/2 inch freetravel ........close and readj freetravel on pedal
Hi all, I found the specs for the the pressure plate fingers, I was told to set them at 1.8 inches. the thickness of the clutch seems to be correct (.38 inches). I slid the tractor back together and adjusted the clutch pedal rod so that I have 1" of travel before the throwout bearing touches the fingers. the rod is now adjusted in the middle.
I tested it out, it is definitely better. when going from neutral into gear the gears are still turning, nothing like before but would prefer them to be stopped when shifting. any other suggestions?
Thanks, D
/ 2240 Clutch specs info #7
Remember.....H AND LO NOT SINC so engage H OR LO FIRTS AND THEN 1....2.....3......4.....becoase 1.....2.....3......4...... has sincro s
/ 2240 Clutch specs info #8
1-2-3-4 isn't synchronized on a JD 2040 built for N. American sales!!!!!!!!!!
/ 2240 Clutch specs info #9
Unless the serial number is above 350,000. How did the splines look on the clutch shaft? Worn splines can cause the disk to hang up. splines should have small amount of lube on them when assembled.
/ 2240 Clutch specs info #11
OOPS Oldtimers flaring up again!!!!! Thanks for correcting me. It would be interesting to know the serial number of the tractor in question.
Thanks for the info. The serial is 405,xxx. There was no wear on the splines. Although they are dry. It's been a very busy week and I will pull it back a part, to add a little anti seize to them. I'm going to verify that the fingers are adjusted evenly too.
I have to put the tractor back to work tomorrow morning.
Thanks again. Dane
/ 2240 Clutch specs info #13
OK with that SN your tractor has syncronized trans.
2008 Chevrolet Silverado 2500 Crew Cab (A62613)
2008 Chevrolet...
John Deere 825 6R Cultivator (A66408)
John Deere 825 6R...
Smalline 4in. Double Diaphragm S/A Towable Trash Pump (A64553)
Smalline 4in...
Gehl 970 Silage / Forage Wagon (A66408)
Gehl 970 Silage /...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A63569)
2017 TROXELL 150...
2022 CATERPILLAR 272D3 SKID STEER (A65053)
2022 CATERPILLAR...
