which machine for Colorado?
/ which machine for Colorado? #1
Westyparker
Pinewood Springs, Colorado
none yet
My wife and I are moving to Colorado. Our cabin is at 7400 feet and we get an average of 60" of snow. Our driveway is 1/4 mile long with some short parts with a fairly steep 15-18 degree pitch. I have read a goodly amount about all the different makes. I'm trying to figure out which machine would be right for the job. I will be doing tree/firewood work as well but that doesn't seem to put a lot of demand on a machine like the plowing does. Thanks
/ which machine for Colorado? #3
Welcome to TractorByNet!
I moved your thread to the Buying/Pricing/Comparisons forum. :)
/ which machine for Colorado? #4
I have no idea of what dealers you'll have near you, but get something with a turbocharger, or it will be sluggish!
With that much snow, I'd consider a snow thrower over a plow....you quickly run out of places to push it with a plow.
I'd definitely lean towards a cab there as well, and that realistically puts you at least into the high 30hp range. You're definitely going to need 4wd, and likely chains for the tires....I needed them here this year, and it's quite flat ground.
/ which machine for Colorado? #5
Over a mile high you may want a tractor with an engine turbo-charger. If you go with a naturally aspirated engine be sure to purchase ample horsepower to compensate for altitude power loss.
/ which machine for Colorado? #7
Nope it's not a problem. I'm at 8400' with a CT445 and have plenty of power. Neighbor has a CT450, there's little difference between the two.
Other neighbors have Branson, JD, etc., none are turbocharged.
Yes you will definitely want a cab, 4 wheel drive, and a snowblower.
/ which machine for Colorado? #8
Power loss at altitude isn't negotiable, it's going to happen. At 7,400ft, the OP will be down around 22%, and at your altitude you're down over 25% (makes your "45hp" tractor into 33hp, or a bit less).
I'm guessing you've never driven your tractor down from 8,400' to SL to compare how it performs differently? I know I've done that with cars/trucks and the difference is pretty dramatic.
I moved here from a few hours south of Denver (around 7,100ft) so I'm very familiar with power loss at altitude...well that and a pilot's license that requires computing that sort of stuff for takeoff performance.
You can either start with a more powerful naturally aspirated engine to ensure you have enough power left to do the job, or go with something smaller that has a blower to let you maintain more of (in some cases all) what it starts out with at SL. It sounds like the reduced power you have with your Bobcat is sufficient for your tasks, which is great, but it still has a lot less power than it would at SL....no way around it.
/ which machine for Colorado? #9
What is this
tree/firewood work
you write of? A 10' piece of 20" diameter red maple weighs about a half ton. Or five 2' chunks 20" in diameter.
Calculate accordingly.
/ which machine for Colorado? #10
Not only are you down on max power, many of the parasitics stay the same (except fan - you don't have the air for it to draw so its power consumption is down). My last years before retiring I was plagued by marketing types who came to meetings with info saying things like 97% of the earth's population is at less than 1500 foot elevation so don't worry about them. Customer goes ahead thinking the selling company knows what it is doing and the machine won't do the job. Lesson learned is that you need to cover yourself by doing research. Turbos compensate for the lack of air but they also spin faster than they do I denser sir due to lack of air resistance and this faster rotation speed can cause failures so you really need to talk to people in your area who have learned lessons the hard way.
/ which machine for Colorado? #11
Ok so I live in CO, have a Kub 4060 and there's this wonderful invention, maybe you've heard of it: electronic fuel injection? Has the ability to deal with barometric pressure variances up to 14K feet? While a turbo is much cooler than my NA Kub, I'll bet you a beer I dyno at real close to rated HP, just like my fuel injected Jeep does. Now if you plan on running Pikes peak in your tractor you may have issues.
For dealers there's Protesio Brothers (JD) Steel Tractors (Kub) and a couple of used "equipment" dealers. My tractor is at Steel right now for service and a tire fill. Theyre the only ones left in CO doing beet juice.
Welcome to the mountain life, look me up.
/ which machine for Colorado? #12
Consider that at the end of the day engines make power by piston speed and compression. Lower air density at higher altitudes leads to lower compression pressures and less power. While engine management systems bar and map sensors will tell the ECU there is lower air pressure and manifold pressure allowing the common rail direct injection pump to compensate for stoichiometric mixture, power will still be down relative to sea level.
In contrast, turbo applications over-pressurize to the point where as rpm climbs, the turbo must vent excess intake pressure through a waste gate. As a result, turbos have negligible losses due to altitude relative to their performance at sea level and in application only at point where the turbo isn't contributing (i.e. idle and just off of idle).
/ which machine for Colorado? #15
Sounds like a nice place, but be careful on slopes they can be dangerous to deal with. Besides clearing the driveway and fire wood what else will you use the tractor for? How much property to maintain, mowing or brush cutting and any other tasks?
I live in Ruidoso NM and work similar altitudes and feel the turbo diesels perform better than the natural aspirated models.
New/Unused AGT Industrial SDA-140W Mini Wheel Loader (A57454)
New/Unused AGT...
UNUSED WOLVERINE TQH-26-02C 3PT TRAILER MOVER (A62131)
UNUSED WOLVERINE...
2007 Chevrolet Silverado 3500HD (A60462)
2007 Chevrolet...
2012 Volvo VNL Sleeper Truck, VIN # 4V4NC9KK7CN542997 (A61165)
2012 Volvo VNL...
NEW HOLLAND B95B BACKHOE (A62129)
NEW HOLLAND B95B...
2009 Mariah SC23 23ft. Cabin Cruiser with T/A Boat Trailer (A61569)
2009 Mariah SC23...
