Kubota wheel size/ fit between models
/ Kubota wheel size/ fit between models #1
cnice37
Member
Mass
Kubota B2100
CaCl has trashed at least 1 of my rear wheels/ tire. The other side is just starting to bubble. In the event that I can't save them, I have been trying to see what is out there either for new, used, aftermarket and all my options.
I haven't been able to figure out if there is a common wheel between different model tractors. For instance, in R1's will a B2100 mate with something else out there that I may find used? Unfortunately, ebay ads have been my best guide and I can't say I have much faith in those.
There's a listing from the town next door for a used set of turfs, all 4, for $500 off an L2500... these would be way too big but then I was wondering what if I can just use the wheels and and new rubber all the way around that fits the B2100 specs?
I like the R1's, but I'd prefer turfs if the right deal popped up.
Thanks.
/ Kubota wheel size/ fit between models #2
Don't forget you can get custom spacers to increase clearance. Don't know if you'd have problems with diameters not matching 4WD ratios if you put a set of larger wheels/tires on intended for a different tractor, assuming the bolt patterns worked?
That would be a major concern. The information is lacking online, sounds like an excuse to visit a dealer.
8K Series John Deere Saddle Tanks w/ Mounts (A62177)
8K Series John...
New/Unused 1in ALR Impact Wrench (A61166)
New/Unused 1in ALR...
2007 MACK CHN613 6X4 T/A DAY CAB TRUCK TRACTOR (A59909)
2007 MACK CHN613...
2013 GMC Sierra Service Truck, VIN # 1GD422C84DF134632 (A61165)
2013 GMC Sierra...
YANMAR VIO17-A EXCAVATOR (A62129)
YANMAR VIO17-A...
UNUSED TAYLOR-WAY 6' BOX BLADE (A62130)
UNUSED TAYLOR-WAY...
