Attaching Brush Hog on 3pt what kind of top link do you use ?
   / Attaching Brush Hog on 3pt what kind of top link do you use ? #11
I use a hydraulic toplink, although you didn't specify if your new LS had hydraulic rear remotes. In the past I'd always get rotary cutters with pivot point where the toplink connects to the mower. This combination is called a "flexible toplink", and is what permits the mower to float with the terrain (see orange attachment). My most recent rotary cutter however, is not of flexible toplink design. Rather, the metal straps that connect the toplink connection to the mower deck are hinged in the middle. This design is not quite as efficient, but still manages to keep the tail wheel on the ground over most terrain.
//greg//
   / Attaching Brush Hog on 3pt what kind of top link do you use ? #12
I use a solid top link but the way my land lays there is no problem. If I had rough ground I would use a chain or better yet use a trailer hitch type. I used a trailer hitch type for years and like them best.
Ok you stumped me! What is a trailer hitch type?
Google image search didn't show any.
   / Attaching Brush Hog on 3pt what kind of top link do you use ? #13
My RC has the hinge like Greg_Gs orange photo. I upgraded to a TnT kit with float on both axis & quick hitch though. I may end up removing the hinge & just use float to make hitching up a hair easier. A little bit of a pain to catch the floppy hinge with the quick hitch hook.
   / Attaching Brush Hog on 3pt what kind of top link do you use ? #14
Ok you stumped me! What is a trailer hitch type? Google image search didn't show any.
I believe he is referring to a drag or pull type cutter. They hook to the draw bar instead of the three point hitch.
   / Attaching Brush Hog on 3pt what kind of top link do you use ? #15
Yep, that makes sense, thanks. My mind was still up at the toplink, thinking of something to allow movement.
2015 Kia Sorento SUV (A50324)
2015 Kia Sorento...
2020 CATERPILLAR 259D3 SKID STEER (A52705)
2020 CATERPILLAR...
2007 CATERPILLAR D5G XL CRAWLER DOZER (A52707)
2007 CATERPILLAR...
2019 VOLVO L70H WHEEL LOADER (A52706)
2019 VOLVO L70H...
2016 KENWORTH W900 DAY CAB (A56129)
2016 KENWORTH W900...
2017 Mack GU713 Granite Tri-Axle Dump Truck (A51692)
2017 Mack GU713...
