Attaching Brush Hog on 3pt what kind of top link do you use ?
   / Attaching Brush Hog on 3pt what kind of top link do you use ? #1
kingrace78
Prescott, Ks & Lee's Summit, Mo
AC D14, LS XR4046H
Always before on my old AC I used a chain for the top link with a brush hog, this allowed the mower to flex on uneven ground. I just bought a new LS tractor and I am wondering what most people do brush hogging on uneven ground. I would think a solid toplink would bend.
Thanks
John
   / Attaching Brush Hog on 3pt what kind of top link do you use ? #2
My brush mower and finish mower, the link that the 3 point top link connects to pivots. This allows both to follow the ground while limiting travel some and allowing a level lift.
I have also used mowers in the past without attaching the top link.
I know others who have used a chain.
The stuff I mow though is a few fields I have mowed for years just to keep the brush down. Don't know how much a deck could jump if hitting unknown objects or small tree's.
   / Attaching Brush Hog on 3pt what kind of top link do you use ? #3
I use a solid top link but the way my land lays there is no problem. If I had rough ground I would use a chain or better yet use a trailer hitch type. I used a trailer hitch type for years and like them best.
   / Attaching Brush Hog on 3pt what kind of top link do you use ? #4
Another solid top link user. My RC also has the pivoting connection point, which works well enough. I'm not mowing a golf course with my RC, so the occasional scalp is no big deal.
Joe
   / Attaching Brush Hog on 3pt what kind of top link do you use ? #5
Mine has a solid top link, BUT the Bush Hog has chain going from the top link down to the mower
   / Attaching Brush Hog on 3pt what kind of top link do you use ? #6
I use a hydraulic top link which works great for me, even better would have been if I had thought to get it with float, live and learn.
   / Attaching Brush Hog on 3pt what kind of top link do you use ? #7
Solid top link (factory jackscrew) but the Rotary Cutter has a pivoting top coupler that allows for quite a bit of upward movement of the cutter.
   / Attaching Brush Hog on 3pt what kind of top link do you use ? #8
My cutter has a float clevis at the top link. This allows deck to follow ground contour for most conditions but limits it to about 45 degree so it can't rotate/flip up beyond safe operating angle.
   / Attaching Brush Hog on 3pt what kind of top link do you use ? #9
I think the best is the swivel joint at the top on the bush hog. These can be retro-fitted to just about any mower and they give enough movement for even the deepest ditches without binding but still gives a solid link back to the tractor.
Thanks everyone, I will look for a swivel joint. That sounds like the best option.
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A51692)
2003 Pierce Tilt...
Towable Orchard Sprayer (A55851)
Towable Orchard...
2014 Ford F-350 4x4 Cab and Chassis Truck (A53422)
2014 Ford F-350...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
New/Unused 20ft Bi-Parting Iron Gate (A54865)
New/Unused 20ft...
CATERPILLAR 22" PIN ON BUCKET (A52707)
CATERPILLAR 22"...
