Attaching Brush Hog on 3pt what kind of top link do you use ?
   / Attaching Brush Hog on 3pt what kind of top link do you use ? #11
I use a hydraulic toplink, although you didn't specify if your new LS had hydraulic rear remotes. In the past I'd always get rotary cutters with pivot point where the toplink connects to the mower. This combination is called a "flexible toplink", and is what permits the mower to float with the terrain (see orange attachment). My most recent rotary cutter however, is not of flexible toplink design. Rather, the metal straps that connect the toplink connection to the mower deck are hinged in the middle. This design is not quite as efficient, but still manages to keep the tail wheel on the ground over most terrain.
//greg//
   / Attaching Brush Hog on 3pt what kind of top link do you use ? #12
I use a solid top link but the way my land lays there is no problem. If I had rough ground I would use a chain or better yet use a trailer hitch type. I used a trailer hitch type for years and like them best.
Ok you stumped me! What is a trailer hitch type?
Google image search didn't show any.
   / Attaching Brush Hog on 3pt what kind of top link do you use ? #13
My RC has the hinge like Greg_Gs orange photo. I upgraded to a TnT kit with float on both axis & quick hitch though. I may end up removing the hinge & just use float to make hitching up a hair easier. A little bit of a pain to catch the floppy hinge with the quick hitch hook.
   / Attaching Brush Hog on 3pt what kind of top link do you use ? #14
Ok you stumped me! What is a trailer hitch type? Google image search didn't show any.
I believe he is referring to a drag or pull type cutter. They hook to the draw bar instead of the three point hitch.
   / Attaching Brush Hog on 3pt what kind of top link do you use ? #15
Yep, that makes sense, thanks. My mind was still up at the toplink, thinking of something to allow movement.
2008 Chevrolet Impala LT Sedan (A55853)
2008 Chevrolet...
2011 TEM 50' FLARE STACK (A53843)
2011 TEM 50' FLARE...
2018 CATERPILLAR 908M LOADER (A52706)
2018 CATERPILLAR...
2015 AMERITRAIL MANIFOLD TRAILER (A55745)
2015 AMERITRAIL...
Tandem Axle Rear Truck Frame (A55852)
Tandem Axle Rear...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
