Finally got a inclinometer
/ Finally got a inclinometer #1
Kenneth in Texas
Gold Member
Pretty good ways from DFW, Texas
Kubota L2800 4wd, FEL
wow i really had no idea about the angles on my land and places where i use my tractor until i got one of this things. Amazing little item, tractors should come with them from the factory or dealer. 15 degrees is a pretty good angle to me, i cant imagine even staying on my tractor at 30 degrees :eek:
For those of you that have them, whats the biggest slope youve been on and at what degree do you start feeling uncomfortable? Around 19-20 and the pucker factor starts coming in to play. :laughing:
/ Finally got a inclinometer #2
Inclinometers are nice. As are GFI circuit breakers. If you trust your life with those sort of things.
/ Finally got a inclinometer #4
I understand and meant no insult. On hills I simply would not trust a gauge. Just too many variables. I wouldn't send my wife out on a tractor and say "as long as the inclinometer reads this you are perfectly safe." And wouldn't want others to do this also.
no insult taken :drink:
youre right, cant trust a gauge 100% because you can drop in a hole and that angle change in a blink of an eye but for $15 it helps me know generally what angles im at a given spot, of course the pucker factor is the ultimate gauge for me. :)
/ Finally got a inclinometer #6
I have a well worn pucker meter. Let us know how well your inclinometer matches your pucker factor. Your tractor is close to the same size as mine.
/ Finally got a inclinometer #7
I live on a hillside. I've got a gauge that has a magnetic base that shows degrees of angle that I bought at Harbour Freight for a few dollars which I've placed on my hood before to test angle.
Now come my "issue/concern". Mowed across some of my slopes with a BX1500 MMM and "felt" fairly safe. Did it with a BX2350 MMM and BX2660 and "felt" less safe. Did it on a couple of B models and "felt" even less safe and did it on a L3240 and "felt" scared and muscle contracted to extreme closed limit!!!:eek::eek::eek: Now do it on a Kubota F3080 with a 6' deck and "feel" as safe as I did on the BX1500 MMM. Now my question is Did the angle change on the different machines?:confused3: :confused::anyone: If I was using the angle measurer would I have felt different or would I have been safer or less safe?:shocked: :D :D :D
http://www.tractorbynet.com/forums/kubota-lawn-garden/280786-f3080-mowing-hillside-video.html
I have posted a You tube video going across my slope on my F mower on the TBN Lawn and Garden forum.
PS Have "felt" less safe/secure since laying my BX25 on its side.
biggest angle was 21 degrees just for a second but anything over that and i would feel like the need to jump off, in fact call me what you want but on my tractor i wouldnt even consider more than that. Think ive read in the manual not to operate at more than 30 degrees, they wouldnt have to worry about that from me, aint no way i would even approach that. This gauge wasnt as much as a safety factor for me as it was a curious factor since ive often wondered about some of the slopes on my place while driving, well worth the $15 for me.
/ Finally got a inclinometer #9
One of those things I keep meaning to get and will someday more out of curiosity than anything else as like JOHNTHOMAS while angles don't change my internal pucker factor sure does from one machine to another.
/ Finally got a inclinometer #10
I've had an inclinometer for a few years now, as my property is all on a slope and some is pretty steep (>30°). It's one of these:
It only lasted a couple of winters, as I have no shelter for my tractor yet. I'm wondering what inclinometer you purchased, and if it's waterproof?
Pucker wise, I'm pretty comfortable as long as I'm going straight up and down a hill. If it's steep, like it was today while I was bush hogging, I prefer to have the rear wheels uphill. Side hilling is a whole 'nuther story. I start to get nervous at 20°, the tractor gets tippy at 30°, with the uphill rear wheel starting to float up much above that. That's if the traction is good; usually the front will start to slide to the down hill side before the wheel comes off the ground. But many is the time I've had to slam down the FEL to keep from going over, and I pretty much always have it on the tractor for that reason. I also move very slowly at those angles, my hope being that I'll catch something bad happening in time to back out of it. My biggest fears are dropping a down slope wheel into a hole, bumping an uphill wheel over a rock or stump, or getting the thing sliding sideways only to have it regain traction and flip as a result. The bigger the tractor, the higher will be the center of gravity, and the easier it will tip over. That's probably why the smaller B series Kubotas and dedicated mowers feel less tippy: They're built closer to the ground.
/ Finally got a inclinometer #11
Sjmarbu: Any idea where purchased/price like it has fore/aft as well as side/side. Thanx PR
/ Finally got a inclinometer #12
/ Finally got a inclinometer #13
slmarbu: Found it duh amazon $17 + s/h Thanx Should have tried there first
/ Finally got a inclinometer #16
I understand the big emergency brake idea. I've used it myself. But I can also tell you that having the FEL on the front end can make a huge difference in the stability of the tractor. I've only got a BX. It is even closer to the ground than the B. My rears are loaded with washer fluid, so roughly 100 lbs each. I mounted 50 lbs of wheel weights on them and put 275 lbs on my 3pt low to the ground. I then drove over to my hillside which measures at about 20-22 degrees. It always felt tippy to me, so I parked it there, got off, and pushed on the rollbar. I could left the wheel with some effort. I went back to the garage, took off the weight bar, wheel weights, and FEL and parked in the exact same spot. I could NOT lift the rear wheel by pushing on the roll bar. The FEL transfers a lot of weight from the solid rear axle to the tippy front axle. The effects are dramatic at least on a subcompact.
So while it feels good to have that emergency brake on, that brake can be a huge contributor to the problem you are trying to solve.
/ Finally got a inclinometer #17
I agree that with the bucket in the air the CG is shifted up because of the high FEL attachment points. But by dropping the bucket that weight transfers to the ground, and at least in my experience so far, the wheels do as well. I've also had the misfortune of stripping the spline out of a front propeller shaft coupling while carrying a loaded bucket down a steep hill in 4WD. The back wheels were locked solid leaving two brown streaks of dust off the back but having no appreciable effect at slowing the tractor. I left a third in my seat, then remembered all I had to do was lower the bucket to get the thing stopped. My only other alternative at that point was to aim for a rock pile or tree, and that would have both painful and expensive.
2011 Takeuchi TL250 Compact Track Loader Skid Steer (A64553)
2011 Takeuchi...
2009 EZ-GO GAS GOLF CART (A63276)
2009 EZ-GO GAS...
NEW Wolverine GB-11-72W Skid Steer Grapple Bucket (A62679)
NEW Wolverine...
1997 Duraco Dura Patcher 81DJ Towable Asphalt Patcher (A64194)
1997 Duraco Dura...
CASE TV370 SKID STEER (A62129)
CASE TV370 SKID...
2016 Ford Fusion S Sedan (A59231)
2016 Ford Fusion S...
