calling all L3240 OWNERS!! NEED HELP!!
/ calling all L3240 OWNERS!! NEED HELP!! #1
mark2610d
Tennessee
L3240HSTC
I have a l3240 that has a speed sensor and the three wires have come out of the plug that plugs into the sensor. (was into heavy brush and it got snagged) My wires can be slipped back into the plug but I don't know which wire goes where. If you lay under the tractor the sensor is on the right side of the transmission toward the rear just before the rear axle housing. It is a sensor held in place by 1 small bolt. It has three wires going to it via plug. all I need is a left to right wire color placement. The wire harness has a black plastic protective wrap that can be pulled back and you can clearly see which wires go where. Can anyone please help me?
/ calling all L3240 OWNERS!! NEED HELP!! #2
My Brother has a 3240. I'll see it tomorrow. I'll check out the wiring and let you know. Sorry I can't help quicker.
Thanks so much!!
/ calling all L3240 OWNERS!! NEED HELP!! #4
Your a good man Richard! :thumbsup:
/ calling all L3240 OWNERS!! NEED HELP!! #5
I think you can download a wiring diagram thru Messicks... if that helps. Might save some crawling under in the rain...
/ calling all L3240 OWNERS!! NEED HELP!! #6
I take it you tore out the male end and the corresponding female is attached to the tractor? Can you remove the part on the tractor and open it up to view wire placement? If so you can then know where each goes on the male end.
And aren't schematics for Kbota wiring available online, or maybe someone has a service manual with the info?
/ calling all L3240 OWNERS!! NEED HELP!! #7
I have attached the wiring diagram. Hope it helps. If not, I suggest going to your dealer and looking at one. Good luck.
PMH
  • Wiring Diagram.pdf
/ calling all L3240 OWNERS!! NEED HELP!! #8
Crap, I got rained out yesterday and didn't see Brother's L3240, saw it today and totally forgot. I'll see it tomorrow and try to remember. Sorry Mark.
It's Murph's fault, he bragged on me.... ;)
/ calling all L3240 OWNERS!! NEED HELP!! #9
So much for being a good man...:liar:
Thanks. No big rush.
/ calling all L3240 OWNERS!! NEED HELP!! #12
I apologize for the delay. I'll get on it tomorrow Mark.
/ calling all L3240 OWNERS!! NEED HELP!! #13
Did you ever find out what plug this was?
Friend borrowed my tractor and tore apart this same plug also, I gotta replace the part the in on the transmission part also
2007 INTERNATIONAL 9900I (A67714)
2007 INTERNATIONAL...
24Wx25Lx12H Two Car Metal Garage | Durable Metal Garage
24Wx25Lx12H Two...
2017 Ford Escape SUV (A66738)
2017 Ford Escape...
2013 Chevrolet Silverado 1500 4x4 Ext. Cab Pickup Truck (A66736)
2013 Chevrolet...
2022 CHEVROLET TAHOE (A66091)
2022 CHEVROLET...
2012 PETERBILT 348 (A67714)
2012 PETERBILT 348...
