Grapple Front end loader grapple bucket for demolition?
   / Front end loader grapple bucket for demolition? #1
jgibbens
Hopedale, IL
Kubota BX 25D
I need to tear apart the walls of a wood frame house into pieces small enough for loading in a dumpster. My tractor is an L3200 with the skid steer style bucket attach. Has anyone tried using a narrow stump grapple bucket on residential wood frame walls with this size of tractor?
   / Front end loader grapple bucket for demolition? #2
Do you already have the stump grapple bucket?
   / Front end loader grapple bucket for demolition? #3
I would tear it apart with the stock bucket unless you already have the stump bucket. Anyone that has ever accidentally hit the side of their house with the stock bucket on their tractor know how flimsy houses are and how unstoppable a tractor is up against a house. Of course a grapple would be best, but I would try with what I had.
   / Front end loader grapple bucket for demolition? #4
Just recently, I got a stump bucket/grapple. The first thing I did was to tear down a woodshed and deck with it. The grapple crunched the 2x4 walls with T-111 siding. It was easy to pick up everything and put it in a dumpster. Only slow part was the final cleanup. Individual 2x4's and small parts fall out of the stump bucket and have to be hand loaded.
That sounds promising. I dont have a graple bucket yet. What size tractor was used on the shed? The walls are down so I just need to break them up and load them.
   / Front end loader grapple bucket for demolition? #6
I have a NH TC40DA 40 HP. Plenty of power for what I needed to do. BTW the stump bucket digs really well into hard soil, gravel or to dig out rocks, as well as stumps. I really like it. It doesn't hold as much as the regular bucket but works well for breaking up what needs to be moved. I dug out a Hemlock stump the other day that was so big that the tractor would not lift it. Had to push it to the pile. Probably weighed over 1500 lbs.
   / Front end loader grapple bucket for demolition? #7
Looks like you have about 570 - 870 lbs more than my L and probably a lot more bucket force, but I'll try renting one and see how it goes. Thanks.
   / Front end loader grapple bucket for demolition? #9
I think you'll like it. Just think.... a new toy to play with. That almost makes the work worthwhile.
After looking around, I decided to just build one. Don't have photos yet mainly because its one of the ugliest things I've ever made. It is more of a lobster claw than a bucket and its working ok so far. Thanks for all of the advice.
SCAN FOR HAULING AND FINANCING INFORMATION (A52705)
SCAN FOR HAULING...
2015 Ford Taurus AWD Sedan (A55853)
2015 Ford Taurus...
2024 JOHN DEERE 1025R LOT NUMBER 106 (A53084)
2024 JOHN DEERE...
Hyundai HL 960 Wheel Loader (A56857)
Hyundai HL 960...
TANK MANIFOLD (A55745)
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A55314)
2024 BCL...
