Screening Plant Project
/ Screening Plant Project #41
The only sand washers I see are the one that look like water wheels at a mill. And they are all made in china. I'm having some issues with the mesh because its jumping around so much, its breaking at the bottom where I have it bolted to the discharge shoot. I may have to lash it to the frame with wire.
/ Screening Plant Project #42
Thanks, I'll have to see if I can find any info on them. You don't happen to know where I can find some diagrams that show how they work?
DRL
/ Screening Plant Project #43
I love this thread! We are starting our screen plant build next week and have recieved so much inspiration from this site.
If the mesh is breaking, just use some clear silicon to patch holes and where it is metal to metal. The silicon helps reduce the vibration and keeps the screen from breaking.
Thanks for the great info and we will get some pics up when we have some solid progress.
/ Screening Plant Project #44
Good Earth...WELCOME TO TBN...and we're looking forward to your future posts.
/ Screening Plant Project #45
Any new information of the project?
How is the screen plant holding up?
Have you made any changes to the screen plant?
Any new photos?
Any comments on how it was designed and built, what would you change other then a lower hight?
Wonderful looking screen plant, thank you for the info on the site.
/ Screening Plant Project #46
What are the tires used for? Is the frame attached to the table through the tire axles to act as a shock absorber some way? Called today for 35 yards of top soil, they want $900 for the load, think one of these projects are in my very near future.
thanks
Mike
/ Screening Plant Project #47
thanks
Mike
That's almost $26 a yard. You should be able to find nice 1/2" screened loam for around $22 a yard.
/ Screening Plant Project #48
The next best quote I found was 27.75/yard delivered, and they did not even laugh or chuckle when they said it. It has been a few years since I have ordered topsoil but I seem to remember it around 15/yard not too long ago.
/ Screening Plant Project #49
Well, I'm finally done and it works great!! I've screened 30-40 yards with no hiccups. I think I will build a engine guard, to keep an errant rock from hitting the engine.
Somehow I missed this project all these years!
Mark,
You sure did a great job building it!!!, and looks like it works great too!!!:thumbsup:
Very nice!!!... I'll have to add that to my build list!:)... I go down on the riverbank and get rich black topsoil and sand!... But before I use it, I have to pick through it and get the sticks out and other debris.
Thanks for sharing your project!!!, and the pictures!!!:)
Bill
/ Screening Plant Project #50
I had several hundred of topsoil that was grubbed off the land at my girlfriends cabin that was mixed with tree stumps, roots and rocks. All this wonderful topsoil was trucked away and dumped in a pitt. I saw AK's screener and thought it was a wonderful idea to recover this soil rather than pay $300 a tandem for topsoil.
I added a few touches to the screener in order to pick up and move the screen with my JD 2210. Still a few bugs to work out and have to add wings to get rock, sticks, etc from hitting the motor,
Overall I am pretty pleased up to this point
/ Screening Plant Project #51
Very nice job. I saw a manufactured one that sits higher but has a sled under the screen for the good loam to slide off into a pile and the same for the rocks/debries farther away.
/ Screening Plant Project #52
Caper90,
What sizes of steel did you use, and for what parts? It looks mostly like 2x2 HSS, but segments look a bit bigger (maybe 2x3 or 2x4).
What about on the screen, did you use HSS or Angle Iron?
/ Screening Plant Project #53
My entire screener is built from salvaged scrap metal. I went to the local tractor dealer and they were going to throw out all the metal frames that the tractors are shipped on prior to being assembled. It is mostly 2x2 tubing with some 1x2 tubing for bracing.
The screen itself was saved from the scrap yard, it was off an industrial screener and was cut up in sections. I build the frame for the screener out of the 1x2 tubing and welded the pieces of screen to it, then I put angle iron around the edges to lock it down so it would not vibrate free. The segments look bigger just from the angle the photo was taken.
I have screened a lot of dirt with this and have not had an issue with structure or welds. (blew the motor - my own fault for not checking the oil level).
I plan on making a slight change in the design some day. I would get a off balance weight on each side of the screen to maximize the vibration, I found that with the weight on one side it was not vibrating as much as i would like, I messed around with different amounts of weight but still need that extra bit of vibration.
If you have any other questions, fire away. Hope this helps
What about on the screen, did you use HSS or Angle Iron?[/QUOTE]
/ Screening Plant Project #54
how about using an axle all the way though from one tire to the other and fixing your pulley to it. then add a shaker weight to the center. you could raise and lower the angle without having to adjust the belts and both sides would be shaken through the axle. just a thought.
/ Screening Plant Project #55
Hello akpilot...
I have read with interest your vibratory screen construction. I have been looking into a similar project. My inspiration is from YouTube videos of "Dick Searle" screeners, based in England. I have scrutinized his design. His motor drives an axle of probably 1.5-2 inches in diameter that spins an off centered weight that I believe is mounted in center. The bearings supporting this large of an axle with all of the vibration stress are huge. He sandwich bolts the screen to the screen frame.
Another resource I have been reading is:
Screening & Feeding
There is alot of chitchat about screen sizing, table sizing, motors, off center weights, angle of vibrating table, etc. Reading this site, I though it would not be practical for an individual to construct a vibratory screen that would not self destruct from all of the vibrations. But you have apparently hit the sweet spot. I was seriously considering building a trommel instead, to avoid the stresses in the system from the vibrations as the web site talks about.
Anyway, did you think about putting the table on front and back tires, instead of front tires and rear springs? There is another youtube video of a vibration screen using front tires like your design with rear springs. What is the screen size you are using. Dick Searle uses 15 mm as a universal screen, but goes down to 9 mm and 5mm for finer output.
I would enjoy seeing more pictures and if possible a video of your machine in action.
Thanx again.
/ Screening Plant Project #56
Hello Caper90
Your design appears to work well. What are you supporting the rear of the screen table with...springs, rubber mounts? What is the mechanism of your off centered weight to create the vibration. What size of motor are you using.
Thanx
/ Screening Plant Project #57
The back of screen table is supported with 2 coil springs off of a small car, they were cut down so they were not so high. They are just sitting in a piece of pipe on the bottom and I used the rubber bushings off the car for the top part as they sat in perfect. The mechanism I currently have for vibration is an old impeller off a snowblower with weights on one side to make it off balance, I made sure to put a housing around it so I did not have to dodge flying rocks if they landed on the impeller. As mentioned in an earlier post, I would go with a counter weight on each side to add more vibration. The motor is just a 8hp snowblower motor.
Modifications will be made this summer. I'll post new pics when I finish them.
Hello Caper90
Thanx[/QUOTE]
/ Screening Plant Project #58
AK Pilot, Very nice build, you have my wheels turning, I too am need of a screening plant. One question. I was thinking instead of using belts and your weighted vibration mechanism, I would try mounting a flywheel on the motor with a solid arm mounted with a bearing off center on the flywheel say an inch or so. As the flywheel spins the arm would have 2 inches of travel back and forth in a cam type action. The other end of the arm would be mounted solid to the shaker table with a heim type joint. With your experience with your build what are your thoughts?
/ Screening Plant Project #59
I'm late in reading this screener build and thread. Saw a couple of comments and questions relating to springs for the screener so I thought I would re-post my video on my homemade screener where I used sections of car tire for both springs and hinges. The ideas has been working great without any problems related to the use of tires.
/ Screening Plant Project #60
IMG_00000380.jpgIMG_00000325.jpgIMG_00000391.jpgIMG_00000389.jpgIMG_00000389.jpgAKpilot,
I followed your teachings for some time and others who contributed on this post as well.
Copied your design and like yours, works very well, here are a few shots...
Dan
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
Tennant 7400 Compact Industrial Floor Scrubber (A61572)
Tennant 7400...
2018 WESTERN STAR  4900 TRI-AXLE HYDROVAC (A63569)
2018 WESTERN STAR...
ITEM# 3974 1997 Kubota L35 Loader Backhoe (A64047)
ITEM# 3974 1997...
PT 1000 Gallon Supply Tank (A57149)
PT 1000 Gallon...
Bomag Roller (A63689)
