CK2510 poor preperation by dealer
/ CK2510 poor preperation by dealer #61
If you have one rear remote set then either pushing or pulling the single
lever will allow flow through the remote valve to your hoe or other attachment, depending on which way the
dealer plumbed the circuit.
Its odd that moving the remote lever in the opposite direction does not make the pump deadhead...
Yeah, the detented remote valve can be set up either way, and if you push the lever in the opposite way
it is supposed to go, you will send oil in the OUT part of the hoe valve, and out the IN part of the valve. When
you operate a hoe valve with the oil flow backwards, and attempt to dig, you will blow out the inner
seals on the hoe valve. The OUT part of the hoe valve can only handle 500psi or so.
This thread is the first I have heard of Kioti (or Bobcat) providing a hoe return-to-reservoir setup, instead of
a hoe return thu the AUX valve. I plan to convert to the better setup this summer when I remove my hoe
for major maintenance.
/ CK2510 poor preperation by dealer #62
My hoe came with it installed on my DK-35se/hst in 2009. The dealer setup my DK-40se/hst the same way in 2010 to continue using my existing hoe with the new tractor. It's easy as pie to install on the DK Series. One male QD from the hoe goes into the A or B position on your first (detented) rear remote and the return line from the hoe gets a larger sized male QD which couples with a large sized female QD that replaces the fill plug/vent supplied with the tractor. The 'new' Shepards crook vent is fit to a fitting that screws in place of a male plug on the left side of the trans housing near the 3PH top link bracket. The female QD is a right angle one to accommodate fitment. Don't wait for the big maintenance, you can do it in 10 minutes!:thumbsup:
/ CK2510 poor preperation by dealer #63
i just purchased a bobcat backhoe for a ct225 and the bobcat dealer had no idea of this setup.
/ CK2510 poor preperation by dealer #64
I've been running a Rhino 85 backhoe for 10 years on my DK 35. It does not have this setup. And as far as I'm concerned it does not need it.
/ CK2510 poor preperation by dealer #65
Sorry, but Bobcat dealers for the most part have at best had 5 years selling Bobcat branded Daedong built, white Kioti tractors, and few would likely be knowledgeable about this kit. The kit is what should be installed on all of the Bobcat and Kioti tractors with Kioti or Bobcat backhoes. They didn't make the kit for no purpose.
Can't speak to your Rhino hoe in particular, but I can tell you Kioti/Daedong made this kit to allow for better/higher flow and better hydro fluid cooling, both of which are good for the tractor/hoe/operator. If you choose not to use it that's strictly your choice, but Kioti supplies the kit with each backhoe- which should speak to the kit's value to the operator. YMMV.:confused3:
/ CK2510 poor preperation by dealer #66
Doesn't your early DK use a diverter for the hoe, Vince?
Of all the tractors I have had, the first and only ones that use the AUX valve (IN and OUT) to run
the hoe are the Kioti/Bobcats. On my CK30, the fluid does get hot, and I think it could be cooler
with a return-to-tank setup. I did that on my first tractor (L2550) and used a hyd fluid refill
adapter at that time.
I know we are getting off the OP's subject.....
I just got off the phone with R. Snyder of Kioti USA, the VP of Sales and Marketing.
He said that thay have arranged with the local dealer to fix my machine. I calling him now!
Justin at Bassani was real nice. He seemed appalled at the poor work and is going to pick up my tractor next Tuesday.
/ CK2510 poor preperation by dealer #68
My backhoe plugs into the hydraulic block beneath the right side floorboard, with surprisingly small hoses and quick couplers.
Works fine though.
The fluids do get hot when doing heavy backhoe work, but nothing I consider being out of the normal range.
/ CK2510 poor preperation by dealer #69
My dealer tells me that he has never received a backhoe with the kit, and the kit is not available for ordering as either whole goods or as a part. I needed it for my down force kit on my post hole digger, and had to order the six individual parts that make up the kit. It is not like my dealer is just not familiar, as he has been a five paw dealer for a long time and is on the dealer advisory council. I think that Kioti has probably done a poor job in educating their dealers, as some do know of the kit and order it, and others never heard of it.
/ CK2510 poor preperation by dealer #70
AT this point I would call any dealership that tells me the kit isn't included a liar and move on to the next (no matter what his credentials are claimed to be). there are simply too many of us who have seen the kit when the backhoe was unloaded from the truck just as described, included with it and have had it installed without any problems from our dealers.
/ CK2510 poor preperation by dealer #71
I run a Rhino 75 on my CK25. No return to the fill port. Just connects to the rear remotes. I've used it for hours on end. I've only noticed it getting hot once, when I had been working for about 3 hours solid trying to get out a really big double stump. I just took a break. 3 hours nonstop is too long anyway.
When I spoke to the mechanic about fixing all the screwups I asked abut the plumbing. He said that setup is only on the bigger tractors. He said mine would be a return to the valve.
BTW he picked-up on the rear lines being mounted wrong immediately. They had the same hoe mounted on a CK20 on the lot and it was done right. The lines come out the center above the top link and are supposed to have a bracket to hold them in place. They also forgot the rubber boots that cover the levers on the the hoe.
/ CK2510 poor preperation by dealer #73
why don't you try writing to Kioti directly and explaining what you have just told us and see if they won't make it right - btw did you pass up other Kioti dealers to get a lower price for this one - most of us do business with folks we like - does the dealer know precisely why you chose him and do you have it all paid off - sometimes a note to the financing folks will get attention too - nobody wants to have their name trashed publicly - they can take a single unhappy customer but it you find a way to hit them either with financing folks or their main supply office - a dealer does not like that and most of the items you mentioned I think are a matter of the local dealer activity----
/ CK2510 poor preperation by dealer #74
It's been a few years, but I used a CK20 with a Kioti backhoe (KB2365?) for a while. It didn't have remotes at all. It was plumbed in at the loader valve. Don't recall the details of this. It just struck me that it was more of a PITA to remove the backhoe with that configuration, and it didn't have reusable remotes when the backhoe was off. Just some extra info that the dealer does have some lead way on how they install the backhoes.
/ CK2510 poor preperation by dealer #75
Well, that is what I thought about the remote Quick Connect mounting... sounds like they will fix you up.. That first dealer must have hired a 12 year old off of the street. "hey kid, you wanna be a tractor mechanic today"
why don't you try writing to Kioti directly and explaining what you have just told us and see if they won't make it right - btw did you pass up other Kioti dealers to get a lower price for this one---
Read first post or more and you'll get a feel for how the last 3 weeks have been.
The tractor is at the local dealer now and the parts are on order. Kioti USA Customer Service is overseeing the whole thing.
One thing I learned from this is, the dealer you will deal with after the purchase may be more important than what tractor you buy. I'm paying for my learning with 4 weeks of time off.
/ CK2510 poor preperation by dealer #78
Sorry to hear all your problems with dealer prep.
I'd hate to see your selling dealer work on anything serious if they can't even prep a machine.
My dealer did an excellent job of prep. Tractor came washed, waxed, polished and greased. Perfect.
/ CK2510 poor preperation by dealer #79
... One thing I learned from this is, the dealer you will deal with after the purchase may be more important than what tractor you buy. ...
I think Buggs just summed up a key lesson in this CUT ownership business. As a corollary, if you buy from a quality dealer you won't need to correct his prep mistakes after the sale. Still, any machine can break (especially considering what we do with these machines) so after-sale support is still important.
I got my tractor back today. Bassani Power Equip in Hamburg, NJ took care of all the problems with coordination from Customer Service at Kioti usa NC. They had to order new ROPS supports from So Korea and get new rear remote hydraulic lines. They expedited everything and used next-day delivery. Everything looks real good. The rear lines now come out in the center of the tractor and they are secured with a bracket. Looks like nice engineering. They checked over the entire tractor and attachments and re-greased everything. It took some time but they took care of me. I worked my tractor about 5 hours today. Got a lot of work done.:)
2015 FREIGHTLINER CASCADIA T/A 6X4 SLEEPER TRUCK TRACTOR (A59908)
2015 FREIGHTLINER...
2019 Caterpillar 239D3 Compact Track Loader Skid Steer (A61567)
2019 Caterpillar...
1995 Peterbilt 379 Tri-Axle Dump Truck (A61568)
1995 Peterbilt 379...
2008 MACK CHU613 TRI AXLE 16FT DUMP TRUCK (A58018)
2008 MACK CHU613...
Eagle Weathervane (A61569)
Eagle Weathervane...
2016 American Eagle S/A Self Loading Reel Trailer (A60352)
2016 American...
