BX mower attachment: BLECCCHHHHHH!!!!!
/ BX mower attachment: BLECCCHHHHHH!!!!! #1
George the Beagle
Gold Member
Southern Maine
BX 2370
I've had my BX for three years now, and you'd think that by this time I'd be more skilled at putting the MMM on. Of course, I only do it once a year so I don't get a lot of practice. I just finished up putting it on the for summer, and--what a nuisance. I had a 1970 Cub Cadet that had a mower that was easier to put on than this thing. And I have the FEL so I can lift up the front, no less. I have the 54"--I feel for those who have the 48" with the non-rotating guide wheels. I'm 62 so this isn't going to get any easier, either.
There, thanks for letting me vent. :)
/ BX mower attachment: BLECCCHHHHHH!!!!! #2
Ok. I will bloviate some here too then. I have never seen the attraction to MMM. I have always used rear mount finish mowers on a tractor, and felt they do a great job, plus have the advantage of being able to back up under trees. They are also very easy to put on and take off, and very easy to clean and change blades on. Another disadvantage of the MMM is that it is on the tractor and limits your ground clearance every time you want to use your FEL.. So I don't like Mid Mount Mowers, and would not own one.. So there.
/ BX mower attachment: BLECCCHHHHHH!!!!! #3
It's always a fun riot when replacing the mower on the tractor every year. I used to do the swap outs between MMM and snow blower on an ex-girlfriend's BX and it was an exercise in futility because I could never remember how it all went together and it seemed different each time:laughing: NEVER MIND THE DAMNED BAGGER SYSTEM! THAT WAS A PAIN TOO!
Now I have my BX25D and mowing season is looming large right now. By next week I will have the FEL and BH off and the MMM on (hopefully!)
/ BX mower attachment: BLECCCHHHHHH!!!!! #4
My apologies in advance as I cant speak for the BX, but I'm hearing just about all owners of the various makes go through a complaint stage of installing/removing the MMM until they get their system down. Some makes of mmm appear to be easier than others. I'll be the first to admit I prefer the mid mount option over the 3-pt pull behind. I easily recognize there is no comparison in ease of install with the 3-pt. I think that's just personal preference and what you are mowing. The only time I have the mmm on is to mow. I take mine on and off at least a dozen times a year, and has become much easier. It does require me to get out a tarp and lay on my back and get under there to connect the mid pto and connect the height adjusters on the MAX. I probably wont want to do all that beyond my retirement years. I hear you! And I don't think its just a Kubota complaint...
/ BX mower attachment: BLECCCHHHHHH!!!!! #5
Well said browneyes,
I also remove my MMM several times a year and I believe this was easier on Bota BX than it is on my current Branson 2400H. The Branson deck does not clear the front drive shaft and lift linkage without raising the front of the tractor. I believe on most models the PTO shaft is the most trouble some aspect of installing the MMM.
Never used a RFM but I am inclined to believe they are more difficult to maneuver around buildings since the 3 point would allow them to sway some. Big advantage of RFM is it doesn't care what brand of tractor it is connected to unlike MMM which are very brand and model specific.
/ BX mower attachment: BLECCCHHHHHH!!!!! #6
I installed mine about 3 weeks ago. It really doesn't take me very long, maybe 10 minutes, 15 minutes tops. Its really not hard to install, but it is akward. I'm not a big fan of rear mowers, maybe if you had mostly open ground it would be O.K. The problem is when you turn sharp the rear mower swings out even wider, its just not that great for mowing around things in my opinion.
/ BX mower attachment: BLECCCHHHHHH!!!!! #7
Mine comes off several times a year as well. I don't want to run in the woods with it on.
I do agree it is a pain, and last time I forgot to hook up the PTO. Laying out in the field with a bad wing trying to put that shaft on was the first time I thought I should have bought a drive over auto connect green tractor. I would bet in 5 years it will be a real chore for me to do.
Yep, I've thought the same thing. It's the only thing I don't like about this BX. I'm wondering if there's a JD forum that explains if the auto-connect is really as good as Deere illustrates it to be.
/ BX mower attachment: BLECCCHHHHHH!!!!! #9
I gotta say that my B2620 MMM is easier to mount/dismount than the BX2660 that I had three years ago. The main reason that it is easier is based on the ground clearance which gives one more wiggle room for connections especially on the PTO. I don't utilize the drive over method because it isn't necessary. For any extended FEL or 3-pt functions I remove the MMM without hesitation. Although a bit old, I am a small guy so sliding under the rear end to hook the PTO is an option for me.
Cheers,
Mike
/ BX mower attachment: BLECCCHHHHHH!!!!! #10
I HATED taking the MMM off of and putting it back on my BX2200. HATED!!!
Now, with my JD 2720, it's a cinch! It has the drive over deck, and much more room to hook up the PTO. I LOVE the MMM on my JD, and I can take it off/on in less time than the brush hog on the 3 point. I think it takes less time to hook the MMM up on my JD than it took just to slide the deck under my Kubota.
I can't vouch for the AutoConnect, but my drive-over is a piece of cake!
/ BX mower attachment: BLECCCHHHHHH!!!!! #11
I don't think there is a problem with the MMM setup on the BX. If you do it a lot like I do, it shouldn't take you more than 5 minutes.
I take it of 2 or 3 times a week, you learn how to do it quickly.
/ BX mower attachment: BLECCCHHHHHH!!!!! #12
I think the main problem for me with the BX MMM was just the sheer weight and the small amount of clearance to slide it under the tractor. That plus the small clearance to get your arm in to hook up the PTO.
/ BX mower attachment: BLECCCHHHHHH!!!!! #13
I try to install the mmm when the loader is on the tractor. Then I can "jack" up the front with the loader to give more clearance. Then I remove the loader after the MMM is installed. If I install in on concrete, I can do it in about 5 minutes, assuming the PTO shaft cooperates.
/ BX mower attachment: BLECCCHHHHHH!!!!! #14
IMO...
They (MMM's) make a tractor look like a lawn tractor...regardless....
/ BX mower attachment: BLECCCHHHHHH!!!!! #15
IMO...
I really could care less what it looks like....it just needs to do what I want it to do.
/ BX mower attachment: BLECCCHHHHHH!!!!! #16
I just bought mine 3 months ago and I read a lot....A LOT.....A HOLE LOT and what I came away with was that the drive over deck did work real well and no one ever had any issues with it...even on soft ground. Now I also read that the auto connect can be a little fiddley if it is not level, you get off too much to one side or the other, and as the system ages and gets a little play in it the auto connect is even a little more fiddley. This is just what I read.
I really like my BX...it has been a great machine, and the only time I second guessed myself was laying in that field trying to hold up that f-ing shaft while pulling the collar back and slide it on.
I do hope it gets better the more I do it.
/ BX mower attachment: BLECCCHHHHHH!!!!! #17
On a tractor forum, I'm surprised that no one has yet suggested leaving the mower on all the time and buying another tractor.
Bruce
/ BX mower attachment: BLECCCHHHHHH!!!!! #18
I have to take my dads MMM off his 04 BX22 in the fall & put it on in the spring and I like many hated it and tried to delay the spring part as long as possible. I was talking to the dealer I bought my equip from about hating it and he said to put the shaft on first then the lift arms & then the front bracket part. While I still was not thrilled about the task it did go considerably easier to my surprise. Also others are mentioning a drive over deck or sliding the deck under, I have always drove over for on & off. I use a couple of pieces of wood and just ease the front tire down. Is that what everyone means by drive over or am I missing something?
Thanks-
/ BX mower attachment: BLECCCHHHHHH!!!!! #19
I had a BX 22 and my father has a BX23. I had and my father had a MMM. The key is to have if on level and hard surface like a garage floor or driveway. It also helps if you keep the loader on so you can lift the front end a bit for extra room. If you have a BH to lift the rear it's even easier. It takes. E less than 5 minutes to put it on and even less to remove it.
/ BX mower attachment: BLECCCHHHHHH!!!!! #20
I have had the deck off the BX 3 times this year, mowed for the 4th time today. I may take it off again next week. I can take the deck off in 40 seconds and put it back on in less than 2 minutes.
New/Unused Wolverine 43in Mini Rock Bucket (A65583)
New/Unused...
John Deere RM 12R Cultivator (A66285)
John Deere RM 12R...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
Landhonor Mini Skid Steer Quick Attach Grapple Bucket (A66285)
Landhonor Mini...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2017 Lincoln MKC Multipurpose Vehicle (MPV), VIN # 5LMCJ2C95HUL50284 (A65563)
2017 Lincoln MKC...
