BX25 - HST fan blade trashed
/ BX25 - HST fan blade trashed #1
xitian
Chattanooga, TN
Kubota BX25
I just completed 400hr service on my BX25D and found this little surprise. Yea. I had a bro-tech skid plate on too...if there is a will there is a way! :mad:
/ BX25 - HST fan blade trashed #2
Now you can join the BX club.
/ BX25 - HST fan blade trashed #3
Ouch!
That's gotta hurt since you had the skid plate!
I keep reading these BX fan threads and remember several years ago a member had a machine shop fabricate a couple of stainless steel fans.
I wonder how it worked out for him,and if it might be the final answer for BX owners?
Good Luck!
It would be great if someone made a metal replacement or a really flexible one. Working on hunting down part numbers now. Looks like the boot needs to be replaced too.
/ BX25 - HST fan blade trashed #6
Yikes, any idea what got up and over the Bro-Tek?
I have no idea...I never found the fins or a stick. I thought I remember hearing something moving some railroad ties in my yard the other day but I'm not real sure what did it. To Bro-Tek's credit I did have the access hole open where the MMM PTO shaft goes through so maybe it got in that way.
/ BX25 - HST fan blade trashed #8
I had a 2200 before my 2620. One of the main reasons for switching to the "B" series was higher ground clearance and the hst cooler that sits in front of the rad. I know if I try hard enough I could probably knock a filter (fuel,oil, hst).
/ BX25 - HST fan blade trashed #9
Mind filling out?
https://www.surveymonkey.com/s/GWM8T7T
Sent from my iPhone 5s 64Gb using TractorByNet
/ BX25 - HST fan blade trashed #10
I submitted this in another thread so apologies if you've already read it. A couple of weeks ago I had the same thing happen - Brotek rear shield in place (but no front shield) and with the shaft plate also in place; but nonetheless in driving through the woods a thin tree managed to snake its way up and stripped all of the blades in a second.
Rather than go through the prescribed process to replace the fan, I fashioned (an idea from another post) replacement sheet metal blades (only 5 rather than the original 10) and screwed and glued them onto the plastic hub. It seems to be working although only time will tell. I also shielded the hydralic lines next to the fan in the event that a metal blade flies off or (more damagingly) comes partially off and hits the line while spinning.
I like the idea of that. I see a lot of other metal fans for sell on the internet. I wandering if one could be modifed to fit...
/ BX25 - HST fan blade trashed #15
I think I posted this some years back, but if Kubota sticks with the fan for cooling the HST, they should make that "hump" or "bubble" just under the seat a removable panel rather than part of the floor board. Would make it a whole lot easier to get to the fan, though you'd still have to disconnect the drive shaft to RR it. Anyway, nice work, and it do look clean under your BX. Did you wash it or something once apart?
Thanks. Yep I cleaned her up good while it was apart. A cover over the fan would have sure made it easier!
/ BX25 - HST fan blade trashed #18
After reading several posts on the subject I went and checked underneath mine and sure enough the same surprise on my 2011 BX25. Its a PFP (pretty f^&King pathetic) design IMO and not sure I will replace it. My quick solution was; I ordered the BXPanded Under Armor and a 3" Attwood electric bilge blower, cost was $18. The fan moves a good amount of volume, probably more then the factory fan mounted to the shaft in close quarters. I mounted the blower on the topside of the of the under armor to the left of the lift pump and had plenty of room. I then tapped into the lift pump power harness ahead of the connector for the pump so it turns on/off with the ignition. You definitely know the fan is on because it sound like a little turbine taking off until the sound of the diesel comes to life. The fan draw is only a few amps so I'm not concerned of overloading a circuit because the lift pump is a beefy one. I used a male/female connection in case I need to drop the under armor off the tractor for service. The hole install took about 45 minutes to complete and I feel pretty confident there is plenty of air volume cooling the hst now. The fan actually draws cooler air further from the hst and moves it out the rear, checked it with a smoke test. Hopefully this turns out to be a viable solution. Does anyone have an idea what temps the hst are running at? I will be monitoring my operating temps and may install a permanent gauge it more easily to check soon.
/ BX25 - HST fan blade trashed #19
We need pics
/ BX25 - HST fan blade trashed #20
3 Point Plow (A62613)
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
New/Unused Wolverine 84in Snow Pusher (A65583)
New/Unused...
2004 160 LC John Deere Excavator (A62613)
2004 160 LC John...
2003 Chevrolet Kodiak C4500 Flatbed 503372 (A62613)
2003 Chevrolet...
2024 Ford Transit Box Van, VIN # 1FDRU6ZG8RKB10273 (A65563)
2024 Ford Transit...
