BX25 - HST fan blade trashed
   / BX25 - HST fan blade trashed #1
xitian
Chattanooga, TN
Kubota BX25
I just completed 400hr service on my BX25D and found this little surprise. Yea. I had a bro-tech skid plate on too...if there is a will there is a way! :mad:
   / BX25 - HST fan blade trashed #2
Now you can join the BX club.
   / BX25 - HST fan blade trashed #3
Ouch!
That's gotta hurt since you had the skid plate!
I keep reading these BX fan threads and remember several years ago a member had a machine shop fabricate a couple of stainless steel fans.
I wonder how it worked out for him,and if it might be the final answer for BX owners?
Good Luck!
It would be great if someone made a metal replacement or a really flexible one. Working on hunting down part numbers now. Looks like the boot needs to be replaced too.
Found the parts...
   / BX25 - HST fan blade trashed #6
Yikes, any idea what got up and over the Bro-Tek?
I have no idea...I never found the fins or a stick. I thought I remember hearing something moving some railroad ties in my yard the other day but I'm not real sure what did it. To Bro-Tek's credit I did have the access hole open where the MMM PTO shaft goes through so maybe it got in that way.
   / BX25 - HST fan blade trashed #8
I had a 2200 before my 2620. One of the main reasons for switching to the "B" series was higher ground clearance and the hst cooler that sits in front of the rad. I know if I try hard enough I could probably knock a filter (fuel,oil, hst).
   / BX25 - HST fan blade trashed #9
Mind filling out?
https://www.surveymonkey.com/s/GWM8T7T
Sent from my iPhone 5s 64Gb using TractorByNet
   / BX25 - HST fan blade trashed #10
I submitted this in another thread so apologies if you've already read it. A couple of weeks ago I had the same thing happen - Brotek rear shield in place (but no front shield) and with the shaft plate also in place; but nonetheless in driving through the woods a thin tree managed to snake its way up and stripped all of the blades in a second.
Rather than go through the prescribed process to replace the fan, I fashioned (an idea from another post) replacement sheet metal blades (only 5 rather than the original 10) and screwed and glued them onto the plastic hub. It seems to be working although only time will tell. I also shielded the hydralic lines next to the fan in the event that a metal blade flies off or (more damagingly) comes partially off and hits the line while spinning.
2019 Kenworth T880 T/A Wet Kit Day Cab Truck Tractor (A50323)
2019 Kenworth T880...
STOP!!!! PLEASE READ ALL TERMS BEFORE BIDDING!!! UPDATED TERMS!! (A50775)
STOP!!!! PLEASE...
2010 Chevrolet Impala Sedan (A51694)
2010 Chevrolet...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A52748)
2012 UNVERFERTH...
2016 Kawasaki 70 TM 7 Articulating Wheel loader (A52748)
2016 Kawasaki 70...
