5/16 vs 3/8 chain
/ 5/16 vs 3/8 chain #41
I leant a 5/16 grade 70 chain to a guy so he could pull his 33k gvwr 6 wheel dump that was stuck out with his backhoe. It has been fine, although at the time I was kinda pissed because he could have used two chains to even the pull out. Truck had a good load of loam in it too
/ 5/16 vs 3/8 chain #42
I have been switching to locking grab hooks for safety reasons
Yes, those Twist Lock hooks are very nice-we just started carrying them also. We are the first to have the new Twist lock SLIP Hook in stock, these fit 5/16" or 3/8" chain.
Ken's Bolt on Grab Hooks <<Accessories>>
/ 5/16 vs 3/8 chain #43
Tom, I've never saw a hook like that. That would be very handy in those times where you hook a loose chain, get on the tractor, look back, and it's unhooked........ Where do you find those?? I've never saw them in Farm Supply stores.Edit: Sorry, shoulda read on. I'll be checking out KennyD's selection!!!
/ 5/16 vs 3/8 chain #44
/ 5/16 vs 3/8 chain #45
Here is a quick video from the manufacturer:
/ 5/16 vs 3/8 chain #46
That would be real good if it didnt have parts sticking out to snag and get jammed full of crud. As it is its only suitable for lab work.
larry
True, they can snag grass, junk, etc. when dragging. I started using them after hoisting a 500 lb load, looking up to see the tip of the grab hook stuck into a link in the chain rather than as it should be. I was not under the load by any means but I don't need 500 lbs dropping due to not noticing a grab hook slipping out of position.
I do have a few chains which I will keep with standard grab hooks, but certainly not any chain I lift with.
/ 5/16 vs 3/8 chain #47
<img src="http://www.tractorbynet.com/forums/files/trailers-transportation/373442-5-16-vs-3-8-a-sliphook-tl-small-jpg"/>
Thank you, I looked high and low for a slip hook with a sturdy twist lock rather than those finky lever things that get in the way and bend. I never found the model you posted.
/ 5/16 vs 3/8 chain
Thanks everyone for your help. I was very surprised at the price of chain out there. For chain and ratcheting binders for all 4 corners, I was looking at $300+ to buy local. For anyone out there that is looking, I ended up buying 2 - 20 ft chains, 4 hooks, and 4 ratchet binders for $209 shipping included at Mytee Products. Grade 70 Chain - Buy Grade 70 Chain Binder and Load Binders
/ 5/16 vs 3/8 chain #49
Hooking them together with a grab hook is hard on the link so avoid the very hard pulls. Chain with the short link configuration is more resistant to damage from a grab hook. The chain does weigh more tho than std link.
larry
Thanks guys for the replies. I have grab hooks on smaller chains but wasn't sure if larger stuff was different.
I think I'll cut mine and get extra grab hooks and a couple double clevis'.
Spider
Can you explain the short link configuration?
/ 5/16 vs 3/8 chain #50
Spider
It is just as it sounds, the link is shorter and more rounded. I have a 3/8" in that configuration and do not like it much, you have to have the hooks almost at a right angle to the chain so they will slip on. It also holds the hook pointing out so when you pull the binders down they are at a 45 deg angle both the chain and hook. The one I have is in the bottom of the chain box and almost never gets used. CJ
/ 5/16 vs 3/8 chain #51
Is a slip hook harder or easier on the chain links (as far as potential for causing damage) compared to a grab hook?
Also, it would seem the short link type would be somewhat better in a slip application but maybe a little more difficult to work with grab hooks.
/ 5/16 vs 3/8 chain #52
Yes. Slip hooks are easier on the chain.
That has been my experience too.
/ 5/16 vs 3/8 chain #53
Thanks.
/ 5/16 vs 3/8 chain
Well my chain and binders arrived yesterday, 2 days after ordering. Great service. I laid out the 20 ft chains on the floor of the barn, measured the middle, then attempted to cut a link with my 18 inch bolt cutter. Mistake. Snapped a jaw. That grade 70 is hard stuff. I guess I'll put the cutting blade on the grinder this weekend.
/ 5/16 vs 3/8 chain #55
Any chain that can be cut with an 18" bolt cutter is NOT a chain to be used hard with a tractor.
/ 5/16 vs 3/8 chain
This is my first go-round with grade 70. I learn something new every day. :)
/ 5/16 vs 3/8 chain #57
New/Unused Wolverine Quick Attach Trencher (A65583)
New/Unused...
2019 ALLMAND LIGHT PLANT (A65643)
2019 ALLMAND LIGHT...
2021 CATERPILLAR 326 LONG REACH EXCAVATOR (A64279)
2021 CATERPILLAR...
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
2006 Utility 53Ft T/A Reefer Trailer (A64194)
2006 Utility 53Ft...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
