Tire Selection ground speed
/ ground speed #1
mac1
campobello sc
mf 4610.jd 5325
I have a mf 4610 tractor which has no speedometer only tach. the operator manual only list ground speeds for tractors with 16-9-30 rear tires. my tractor is equipped with 18-4-30 tires. can anyone tell me how to determine ground speeds with this rear tire?
/ ground speed #2
Multiply the listed ground speeds by 1.047, this is based on the difference in the rolling circumference of standard ag tires.
/ ground speed
thank you for the information.
/ ground speed #4
OR easier still, just take your GPS unit and a note pad. Operate the tractor in each gear, noting the GPS ground speed and write it down. You can even make a spread sheet at various RPM for each gear and then laminate it and put it on your tractor. Years back, the farm tractors came with a dash chart showing the various speed of each gear at certain RPM. I haven't seen them on any CUT or Utility tractors though.
/ ground speed #5
Great idea! :thumbsup: And for those people without a GPS unit but who have smartphones there's probably an app that will give you a speedometer function.
/ ground speed #6
Maybe this will help.
2006 Chevrolet Express 3500 Cargo Van (A59230)
2006 Chevrolet...
INGERSOLL RAND  G25 GENERATOR (A60736)
INGERSOLL RAND...
John Deere 4520 (A60462)
John Deere 4520...
2011 SOUTHWEST  GOOSENECK (A58214)
2011 SOUTHWEST...
2011 DOOSAN G25KW GENERATOR (A58214)
2011 DOOSAN G25KW...
2009 Ford F-150 Ext. Cab Pickup Truck (A60352)
2009 Ford F-150...
