5/16 vs 3/8 chain
/ 5/16 vs 3/8 chain #1
AaronS
Santa Claus, Indiana
LS XR4046HC, New Holland Boomer 1020
I'm getting ready to buy chain and ratchet binders to secure my new tractor on the trailer, and want to make sure what I buy is heavy enough. Will four 5/16 chains (grade 70) be sufficient or should I buy 3/8? Thanks in advance.
/ 5/16 vs 3/8 chain #3
Each 5/16 gr 70 has a WLL of 4700#.
So with 4 of them you should be able to tie down 18,800 lbs of stuff. So yea, they are big enough.
But I would suggest the 3/8 if you plan on using the chain for other things, like using with the tractor to drag logs or whatnot. But if only for transport, the 5/16 should be fine.
/ 5/16 vs 3/8 chain #4
I agree with LD1 that 5/16th chain is probably sufficient for tiedown, but I will quibble with the math. When you slam on the brakes or go around a sharp corner a bit fast, only two of the chains are doing most (nearly all) of the work of holding the equipment down. Even so, it isn't as if you were trying to suspend the tractor by the chains...even if you managed to roll the tractor/trailer down an embankment, the 5/16th chains might well hold it all together, if some anchor point didn't give way! Don't try this at home, kids.
/ 5/16 vs 3/8 chain #5
Thats only the WLL too. I think the ultimate break strength of chains is 4x the WLL. SO in theory, it would take 37000lbs to break two of the chains.
/ 5/16 vs 3/8 chain #6
5/16" is fine. Lowes has the best deal on it. They are 20' long. Buy 2 and have them cut it in 1/2 then add 4 mor hooks to the cut ends and you are set.
Chris
/ 5/16 vs 3/8 chain #8
I have all 3/8". I wish I had 5/16" but I am not switching out everything, just too much money. I actually use a 5/16" to drag logs and lift with, hasn't broke yet. CJ
/ 5/16 vs 3/8 chain
Thanks everyone for your replies.
CJONE, what is the reason you would prefer 5/16" over 3/8". Weight? I'm usually one that prefers overkill when it comes to protection/insurance, so I just wondered.
/ 5/16 vs 3/8 chain #10
In practicality, you want the two binder chains to = or exceed the maximum weight that you are tying down. 3/8=5200 pounds WLL so that is what I use to tie down my 10,000# tractor with one on each corner and then I add a nylon strap to hold the FEL as required by law. When hauling my 4000#TLB, I put a ratchet strap across the FEL and one on the backhoe plus the 4 - 3/8" chains. It's not going anywhere.
/ 5/16 vs 3/8 chain
That makes sense, thanks Gary. With FEL the 4046 should weigh around 6000 lbs so 5/8" should be plenty.
/ 5/16 vs 3/8 chain #12
^^This^^ Min break strength of 5/16" Gr 70 is listed as 18,800# Its what they use on the Jerr Dans. Enuf to fold most trailers in half.
larry
/ 5/16 vs 3/8 chain #13
If you have deep enough pockets, consider 5/16" grade 100. It is lighter than 3/8" grade 70 transport chain and almost as strong. The break strength is high enough to cover anything you're likely to carry.
That said, my chain is all 3/8" grade 70.
/ 5/16 vs 3/8 chain #14
Heck why not gr120?
Unless pulling anything, anything more than 5/16 gr70 is overkill. Why pay 3 or 4x's more for something that is of no benefit?
/ 5/16 vs 3/8 chain #15
I would be curious if anyone here has broke 5/16 grade 70 and how?
/ 5/16 vs 3/8 chain #16
I have not and I use only 5/16. I have snapped those 10,000 lb tow straps*, but never a chain.
*And ended up towing out with 4700 lb rated gr70 5/16 that did not break.
About the only thing I use the tow straps for anymore is lifting animals stuck in the mud.
/ 5/16 vs 3/8 chain #17
I have skidding logs. Once with the Kubota, and once with my old dodge. The old dodge, it was momentum that broke it. Was skidding along around 8-10 mph and the butt caught a low-cut stump I didn't see. That dodge also made a 5/16 chain un-flexible by stretching the links and they pinched down on eachother.
The time with the Kubota was also skidding a log. About a 20-24" or so ash top. Chained short and with the 3ph raised to get the butt in the air and have maximum traction. Also had loader on and loaded r1's. So tractor was 4k or so + a good bit of weight transfer and slightly downhill. No jerking. Just an easy pull. Moved about a foot and snap. Got a 3/8" and finished.
I have also broke 3/8" gr70 chain more than once. Twice within a few minutes of each other. But had to get the job done. Was demo-ing an old farm house. All rough cut lumber. The "island" of walls in the center of the house surrounded the cinder block chimney. It was all that was left standing and couldn't get the how close enough to knock it over cause of the basement. So pulling was the only option. Dads ford 4500 (12k lbs) would just spin. I hooked to it with my 5500. Again, no jerking. Just a slow steady pull in 1st gear. Ended up breaking 2 chains before we got it down.
/ 5/16 vs 3/8 chain #18
Yes, the weight when fishing the chains through hitches and just handling in general. When I was hauling 20000lb dozers and loaders the 3/8" was needed but for these small tractors a 5/16 grade 70 is more than enough. Have I broke 3/8" grade 70's, yep but it was with winches on the back of D6 cat dozers or pulling loaded trucks out with other trucks and shocking the chain. I have never broke a grade 70 chain either 3/8 or 5/16 using them as intended. A lot of the chains I see broke are standard hardware store chain that do not have a load grade stamped in the link. Grade 3 is a proof coil chain and is only rated to 2650 for 3/8" and 1900 for 5/16. So there is a big difference from grade 3 to grade 7. If they don't have the stamping they are not a graded chain. And yes the DOT will look for this in commercial applications and you will be fined and red tagged if it is required and you don't have graded 7 transport chain. CJ
/ 5/16 vs 3/8 chain #19
Actually you may not be fined if the proof coil rating is sufficient. If they aren't marked, the DOT regards them as the lowest grade of chain made regardless of what they may be in actuality(SEE DOT REGS). Many old chains aren't stamped so you get stuck with lowest grade of spec which may be ok if you are lightly loaded. As for nylon straps, If they aren't marked, I have no idea how you could rate them perhaps on thickness and width but I wouldn't take a chance with them
/ 5/16 vs 3/8 chain #20
Chris
HF is also a place to look WHEN they have them on sale AND you have a 25% off coupon.
I go to HF about once a month, chains are just a consumable I pick up there when there isn't anything else to use the 25% off coupon on.
Only after skidding logs across pavement and having worn the links thin.
2025 Vicsec 30in. Bucket Mini Excavator Attachment (A64553)
2025 Vicsec 30in...
2022 Mack Pinnacle T/A Day Cab Truck Tractor (A64556)
2022 Mack Pinnacle...
Heavy-Duty Round Livestock Bale Feeder (A66408)
Heavy-Duty Round...
Bush Hog 176 3Pt Blade (A66408)
Bush Hog 176 3Pt...
2016 Volvo VNL T/A Sleeper Cab Truck Tractor (A64556)
2016 Volvo VNL T/A...
2023 JOHN DEERE 450P LGP CRAWLER DOZER (A65053)
2023 JOHN DEERE...
