Middle Buster or Subsoiler for Water Pipe Trenching? Or just rent a trencher??
/ Middle Buster or Subsoiler for Water Pipe Trenching? Or just rent a trencher??
Unfortunately, my water line will have LOTS of "T" joints - one every 13 feet over a total length of 180 feet. Although the "main line" out to the "T" area is much longer with no "T" joints.
At any rate, in thinking about this I thought the Middle Buster might be a better choice as it would leave a larger trench to work within. I think what's going to drive me back to a Ditch Witch rental will be the needed depth. The rental rate isn't an issue, it's just needing to be done in a day that had me looking for alternatives. I have the run described above that I'd like to do next week, but then I need to do a second area about a month from now and I really didn't want to rent the unit twice. I imagine I'll just wait until both fields are complete before I rent and then do them both at once.
/ Middle Buster or Subsoiler for Water Pipe Trenching? Or just rent a trencher?? #12
Here is what a middle buster trench looks like. Used it to bury a 4" drain. Biggest prob is the dirt that kept falling back into trench. This was only abt 120' so I could go clean it out with a spade.
I'm about to lay 400' of electric conduit and 200' of water line so I'm gonna get a walk behind from Home Depot for about $140 a day.
Nice work! Thanks for the visual!
How many feet of lines are you burying, and what diameter?
I would probably use the subsoiler unless there were a lot of complex right angles/etc. where you couldn't simply weave through. The L3130 will pull it fine. It will go quite fast. You will need a helper to unspool the irrigation line unless you build a spool mount for it. The black HDPE pipe does not recover well from being kinked.
A middle buster doesn't really get down far enough and makes somewhat of a mess... the subsoiler leaves a very small trench you can almost pack right over by driving over when you're done, it doesn't even heavily disturb the sod.
I'm about convinced there is nothing the L3130 can't do! It's currently got a Landpride RTR1274 Tiller on the 3-pt and we're tearing up acreage right and left. Just tilled right at 1.5 acres with it and it never missed a beat. Well, there was one spot where we hit a Huisache root - but those things are TOUGH!
But to answer your question - the pipe I need to bury is 1/2" PVC (or whatever they call it now). I can't use the flexible stuff as I need to have "T" fittings every 13 feet. At those junctions we'll connect to the flexible drip lines which will run the length of the vineyard rows, but those aren't underground - they ride on a wire about a foot off the ground.
/ Middle Buster or Subsoiler for Water Pipe Trenching? Or just rent a trencher?? #15
I built a pipe layer to attach to a subsoiler using some 1-1/4 sch 40 pipe bent using a hydraulic pipe bender. Pretty similar to the Agri-Supply one. I trenched in 600 feet of the 1" 100psi coil pipe. It runs to a hydrant at my pasture and this year it froze twice when we had single digit temps. That was the first time it froze since I installed it about 8 years ago. It worked fine again after it thawed.
I ran the subsoiler along the route "dry" before I laid the pipe. At the joints I would install the hose barb coupling, run it into the ground, then pull the pipe up slightly in the trench to install the hose clamps and then push it back down. You could probably do something similar to install tees, pulling the pipe up a little, cutting it, and installing a 99 cent hose barb tee. I used a hand trowel to clear the trench a little where I accessed the pipe. It looks like the irrigation tees don't even need clamps. Mine went in about 12" deep.
Wow, the 1/2" irrigation pipe at Lowes is less than $50 for a 500' roll.
http://www.tractorbynet.com/forums/...156d1305078825-laying-water-pipe-img_3363-jpg
Check out this thread for more ideas. http://www.tractorbynet.com/forums/attachments/206527-laying-water-pipe.html?highlight=subsoiler
/ Middle Buster or Subsoiler for Water Pipe Trenching? Or just rent a trencher?? #16
I have Sandy Loam soil. Just run your middle buster two or three times. We have an old mule plow with a 3 PT welded up. Just ease along so you don't break the plow. Trenchers don't go fast and tractor should be walking speed max. Middle busters are made for worked ground. I have a relative that breaks everything. Other people used it 125 years and 15 minutes of him it's thrown in the scrap pile, him claiming it was a piece of junk anyway. Seen him snap a 6' Ford blade going fast the way he likes it. Had a roller with a 3" solid rod through it. Few minutes it was a two piece special. Came by with it chained to rear of a disc and it was bouncing off the ground 3 ft high on a gravel road while he was traveling. I stopped said slow that thing down. Oh it'll be fine. Took back off, snap, more junk. It was 100 years old and they never broke it, but just a few minutes of him... I do have a case maxi sneaker but I have never done pipe. I do want to change up one plow to do up to 1 1/2" pipe and direct burial cable. You run 3/4 I'd think.
/ Middle Buster or Subsoiler for Water Pipe Trenching? Or just rent a trencher?? #17
Walk behind trencher is pretty easy and quick enough. It is better than a tractor when the going gets tight.
/ Middle Buster or Subsoiler for Water Pipe Trenching? Or just rent a trencher?? #18
I would be concerned with your choice of 1/2” pipe. Over the distance you indicated I think you will find that the trees at the end of the line get little water due to pressure loss over that distance and number of tees.
/ Middle Buster or Subsoiler for Water Pipe Trenching? Or just rent a trencher?? #19
You cant lay PVC with a middle buster or ripper shank. If you do your only going to use it to break up the ground then hand shovel the trench out.
2021 MULTIQUIP WHISPER PORTABLE AC GENERATOR (A59823)
2021 MULTIQUIP...
Kuhn FC400RG (A60462)
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
UNKNOWN TANK MANIFOLD (A58216)
UNKNOWN TANK...
2009 Bobcat 430 (A60462)
2009 Bobcat 430...
2017 Ram 2500 4x4 Crew Cab Pickup Truck (A60352)
2017 Ram 2500 4x4...
