Best attachment for clearing roads/trails after loggers mess
/ Best attachment for clearing roads/trails after loggers mess #41
/ Best attachment for clearing roads/trails after loggers mess #42
Have a wide grapple with close spaced tines and it does just fine even rakes, scrapes and levels and picks up large rocks and boulders.
The L4330 is a larger tractor with the LA853 loader that is bigger in every way.
David Kb7uns
Sorry. Too big for your tractor. Youll encounter many limitations pushing it.
This is going on a LA853 loader that has a 72" HD bucket so this will clear the same width as as the bucket would and the grapple is much lighter. I'm not digging up a house..... :rolleyes:
Larry, if all he is doing is going forward and picking up loose stuff, what are his limitations going to be :confused3: other than the grapple gets full very fast. It's not like he is digging in the ground with it, anyway that is not my understanding of the situation. :confused:
Maybe it's a set of conditions that just has to be seen in person. I don't see any problems, or very few. Wouldn't know for sure without being there. ;)
Yea, you go it Brian. These are hard pack dirt roads with pine scraps left over laying in the road. Just the landscape rake would do the job but having the grapple will help with picking it all up.
If it is too big for tractor then why can my L3130 do this?
WOW! :eek: That's impressive David. I think the LA853 then should have no problem picking up some pine scraps...... :rolleyes: Not sure what Spyder is talking about.
What does that have to do with the width of the grapple?
What does the width of the grapple have to do with whether or not it can pick up a pile of loose pine scraps laying in the road? Not sure we are following you with no explanation.
/ Best attachment for clearing roads/trails after loggers mess #46
LSU, please check your PM, I need to confirm your loader joystick shaft dia.
/ Best attachment for clearing roads/trails after loggers mess #47
It has to do with variable and unexpected circumstances you will run into unless your present situation is homogeneous, and future use is largely identical. It has to do with force ability when needed. It has to do with awkwardness of size limiting your options. Etc.
Does it have to do with moonbeams and lucky charms.......??.... :duh:
WTH was that..... :confused2:
/ Best attachment for clearing roads/trails after loggers mess #51
Unless these grapples are way overweight they should be a good match for the machine, I can rake and stuff mine full of branches and they are nowhere near maxing out the loader and I can pick up grapple filling logs that are decent length to move also.
Here is a Locust trunk log that is close to max on the LA723 loader so decide if this grapple limits the use of this GL3130 tractor
David Kb7uns
/ Best attachment for clearing roads/trails after loggers mess #53
Holy cow! I guess that's one way to keep your tractor from tipping over sideways.
It seems I haven't been working my tractor hard enough.
/ Best attachment for clearing roads/trails after loggers mess #54
It's a pretty good amount of trails and rolling hills with a few shallow creek crossings.
Looks like the grapple is the way to go. Spoke with EA today and they seemed to think also that the grapple would be best but both would be better..... (naturally). Made sense though. Said run with the grapple down to grab the bigger stuff and the rake pulling behind will grab all the smaller pine needle sections and looser debris that would fall through the grapple.
I will agree with EA on this one . If the stuff in the road you are trying to remove is pine needles and not full size tree roots a landscape rake and grapple will probably work. we cleared pine needles this way...
Salaras field -pine needle removal 001.JPG Salaras field -pine needle removal 004.jpg
If you have larger embedded slash in the road- and your box blade has rippers you could loosen the debri and then rake it .
Once that is done grapple it up and go from there... In removing these pine needles the rake did all of the gathering and then the grapple just removed the piles.
good Luck with whatever method you choose :thumbsup:
Ah - i should have read the whole thread instead of posting after only reading up to page 3 - Congrats on the new implements i think they will serve you well.
/ Best attachment for clearing roads/trails after loggers mess #56
Thanks dan. Yes, just loose pine debris left over in the roads that is laying on top. No roots to dig up with this job.
/ Best attachment for clearing roads/trails after loggers mess #58
Boy that equipment looks like the makings for a pretty darn nice shop.
Looks like the grapple is the way to go. Spoke with EA today and they seemed to think also that the grapple would be best but both would be better..... (naturally). Made sense though. Said run with the grapple down to grab the bigger stuff and the rake pulling behind will grab all the smaller pine needle sections and looser debris that would fall through the grapple. May just try the grapple and see how it goes then possibly add just the rake in the rear and wait a bit on the TNT.
I agree with what EA said. On the areas were there is light debris use the rake to pile it up and then move it with the grapple.
I am very pleased with how my 72'' Wicked grapple preforms on the L4240.
This stump was partially uprooted.
Log that weighs between 3000-3500lbs.
One thing I want to caution you on to have a proper ballast on the 3PH when you are working the grapple hard. If you are just cleaning up some loose light brush you should be okay with the rake if your tires are filled. If you get to working the tractor/ grapple hard by picking up big heavy loads or digging out stumps or rocks you will need something heavier on the 3PH. Also remember to keep the loader low especially when carrying a load.
/ Best attachment for clearing roads/trails after loggers mess #59
Congrats on your new EA toys. I am in a pretty much the exact same situation. I just had 8-9 acres clear cut (except for 30-40 scattered mature hardwoods). The cut was red pines , row planted 6-10 feet apart and never thinned. They were 60' tall and 8-10 inch, falling over like tooth picks in the wind by the day so I had no choice.
Just received my EA 60" root grapple and I have the EA 72 inch landscape rake on the way(Sounds familiar??).The grapple is a beast, well built, iron-art !.I know you have already orderd, but I had 2 cents to add.
My tractor is only 30 odd hp and 800 lbs lighter than yours but I will say to Spyders point, it depends on alot of things. Buckets are usually used in open areas, but if you eventually start swinging around the woods , you might appreciate a narrower grapple. Also going between stumps/trees, or other obstacles. Running tines in will go better with more pressure on less tines,but still pick up mountains of scraps with
I would call those guys at EA again just to discuss your specifics. It's not just about weight, price and width.They're so busy, I doubt they started welding yet. It's what will work best for all situations. 6 inches doesn't sound like much until you need 6 inches clearance. Don't get me wrong , if your going to be in wide open spaces forever then by all means wider is better.
I mow 2+ acres of grass and while the 72" Exmark zero turn was tempting me to buy,I went with the 60" and it still gets it done in an hour , getting around trees, house , playhouse, pool and all the crap mother puts out in the yard! and the push mower is in mothballs!
Either way , your going to love the EA stuff (Christmass in May!!), great people and great tools. Good luck and take care
Brian
/ Best attachment for clearing roads/trails after loggers mess #60
Brian
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2018 FREIGHTLINER...
2015 Ford Taurus AWD Sedan (A61569)
2015 Ford Taurus...
UNUSED KJ 11'X19' ALL-STEEL CARPORT (A62131)
UNUSED KJ 11'X19'...
2004 Peterbilt 357 Tri-Axle Dump Truck (A61568)
2004 Peterbilt 357...
2017 CATERPILLAR 262D SKID STEER (A62129)
2017 CATERPILLAR...
2011 JOHN DEERE 544K WHEEL LOADER (A62129)
2011 JOHN DEERE...
