Best attachment for clearing roads/trails after loggers mess
   / Best attachment for clearing roads/trails after loggers mess #41
   / Best attachment for clearing roads/trails after loggers mess #42
Have a wide grapple with close spaced tines and it does just fine even rakes, scrapes and levels and picks up large rocks and boulders.
The L4330 is a larger tractor with the LA853 loader that is bigger in every way.
David Kb7uns
Sorry. Too big for your tractor. Youll encounter many limitations pushing it.
This is going on a LA853 loader that has a 72" HD bucket so this will clear the same width as as the bucket would and the grapple is much lighter. I'm not digging up a house..... :rolleyes:
Larry, if all he is doing is going forward and picking up loose stuff, what are his limitations going to be :confused3: other than the grapple gets full very fast. It's not like he is digging in the ground with it, anyway that is not my understanding of the situation. :confused:
Maybe it's a set of conditions that just has to be seen in person. I don't see any problems, or very few. Wouldn't know for sure without being there. ;)
Yea, you go it Brian. These are hard pack dirt roads with pine scraps left over laying in the road. Just the landscape rake would do the job but having the grapple will help with picking it all up.
If it is too big for tractor then why can my L3130 do this?
WOW! :eek: That's impressive David. I think the LA853 then should have no problem picking up some pine scraps...... :rolleyes: Not sure what Spyder is talking about.
What does that have to do with the width of the grapple?
What does the width of the grapple have to do with whether or not it can pick up a pile of loose pine scraps laying in the road? Not sure we are following you with no explanation.
   / Best attachment for clearing roads/trails after loggers mess #46
LSU, please check your PM, I need to confirm your loader joystick shaft dia.
   / Best attachment for clearing roads/trails after loggers mess #47
It has to do with variable and unexpected circumstances you will run into unless your present situation is homogeneous, and future use is largely identical. It has to do with force ability when needed. It has to do with awkwardness of size limiting your options. Etc.
Does it have to do with moonbeams and lucky charms.......??.... :duh:
WTH was that..... :confused2:
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51691)
2009 Hino 268...
2010 Turfco Mete-R-Matic III Pull-Behind Top Dresser (A51691)
2010 Turfco...
2017 JOHN DEERE 350G LC EXCAVATOR (A52705)
2017 JOHN DEERE...
2014 Dodge Ram 4500 Versalift Bucket Truck (A52377)
2014 Dodge Ram...
2010 DOOSAN G25 GENERATOR (A53843)
2010 DOOSAN G25...
