Potato Plow
/ Potato Plow #21
If a guy like me only had three rows 30 feet long of potatoes to harvest this fall...........would middle buster make do , or is better to just use FEL bucket from sides after rest of garden harvested ?
I am worried my wife planted rows to close anyway for my BX2660 with 42" wheel width ...........but what are thoughts for a small farmer/garden like me ?
I have middle buster , FEL or tiller to chose from
jake
Jake, if you have a middle buster that'll work just fine for harvesting potatoes. My middle buster has a 14" wide plow similar to the one in this photo from agri supply's web site.
FURROWERS - Agri Supply
If what you have is a soil buster with only a thin subsoiler point you can always buy just the furrower for around $16. Cheaper than buying a middle buster.
/ Potato Plow #22
Since the 3ph doesn't have down pressure, you will need a tooth or 2 to bite into the ground and start the digging action. Maybe a tooth welded flat on each side (left and right sides) of the cutting blade, extending a few inches forward of the blade edge. That might catch the soil enough to pull the main blade into the ground.
That would probably get it to dig. Do you think the teeth would puncture the potatoes?
/ Potato Plow #23
2manyrocks:
If the top link is shortened it should bite and dig in to lift the spuds.
HTH
Arkaybee
/ Potato Plow #24
I was picturing a 'tooth' on each side, flat on top of the cutting bar, in the corners along the upright cutters. 1/2" thick, 2" wide by 6" long, with only 3" overhanging the front edge and the other 3" tacked on top of the lower flat edge/cutter. That would put them to the outside edges of the potato row. It would also be in line with the existing bottom edge, and slightly deeper, so they would not run into any more potatoes than your current bottom edge. I'm just brainstorming by looking at your plow. I know that plow would not dig into my hard soil either without something to start the cut and pull it down.
/ Potato Plow #25
Thanks. Now I get it.
Only problem now is I missed out on getting potatoes to plant this year.
/ Potato Plow #26
I use this dual plow to get my spuds out.
/ Potato Plow #28
About 3 years ago I saw one that was in the u shape and had a thin flat beveled edge like a dirt scoop. The man said it would dif in like a scoop and he had the rods attached to the back of it on a pivot. He had a short pto shaft hooked to the pto and a set of pillow block bearings on the digger. he had an offset shaft on the side with a small connecting rod on it down to the the rods. That made them shake. It also helped with the digging. His devie also worked on peanuts to. Right now we only use a middle buster but I have been growing them in some baskets with leaves.
/ Potato Plow #29
johndeere4300
Yes we did have had a hard time keeping Grass mowed this year. Green beans doing OK .
Corn real good if I can keep Dear out. Should have corn next week. Wife has caned 40 QTS of Half runers so far. Will start on tamotos this week.
/ Potato Plow #30
I don't have pictures of my homemade one, but looks almost identical to first photo . Trust me it works great!! brings the potatoes up to the top as slick as can be. made mine with scraps laying around and the tines were old electric fence posts. easy build. I should mention my tines were welded to a cultivator tip and angled slightly downward so it digs in. like I said it works great , I'll never hand dig again.
/ Potato Plow #31
The tined potato plows pictured work great.I made one for my David Bradley using a 10" cultivator sweep and 1/4" bar stock welded to the vertical
shank swept back and angled up.I had used a middle buster the previous harvest and it it beat hand digging but the spuds rolled back into the
furrow.The tines help with this problem.The nice thing is that even if you don't get all the potatoes the first pass then the tractor doesn't care how many times you plow the row and I have less skewered potatoes than hand digging.Luck,JimAnderson
/ Potato Plow #32
I hope this gets bumped up. I know this thread is old but, I am searching for answers now rather than waiting untill I need to dig potatoes in the fall. Does adding the tines to the back of a middlebuster type plow really help bring the potatoes up to the surface?
I have dug potatoes with a middle buster (without the tines) before and it beats digging by hand but, I always had to make several passes and stop between each one to pick up the spuds or they would get burried again on the next pass. With 800 to 1000 foot of potatoes that gets old. I can't afford a new digger so, if adding the tines can help, I am sure I can modify what I have. Thanks for this site and any advice available.
/ Potato Plow #33
Google Potato Digger, there are several diggers on their that wouldn't be to hard to copy.
Also look at homemade potato digger on google.
/ Potato Plow #34
The tines definitely help lift the potatoes out of the furrow.In my case the David Bradley has been modified to move much slower than it was designed to.I suspect that a higher forward speed would flip the spuds futher away from the furrow.I would add them to the middle buster.The time and money
spent on this mod will be minimal and if you aren't happy with the change you can remove them with little effort.Luck,JimAnderson.
/ Potato Plow #35
Thank you Jim. I had thought the same thing that they could be removed if I didn't like the results. I'll give it a try.
2022 WESTERNSTAR DAYCAB 4700 CONCRETE MIXER TRUCK (A67714)
2022 WESTERNSTAR...
BODY LOAD TANK (A67714)
BODY LOAD TANK...
2015 Ford F-750 Party Shuttle Bus (A66736)
2015 Ford F-750...
DEERE 544K Quick Attach Coupler (A68134)
DEERE 544K Quick...
2022 CATERPILLAR 299D3 SKID STEER (A65056)
2022 CATERPILLAR...
CAT 963D 4-in-1 Bucket (A68134)
CAT 963D 4-in-1...
