widen rear tires
/ widen rear tires #1
chuck172
N.E, Pa.
Kioti DK40SEH, Ford 4500TLB, Ford 8n
Can you adjust the width of the rear tires on a ck35?
They are not split-rim.
/ widen rear tires #2
If your centers don't unbolt from the ring then the answr is no, I'm pretty sure you cant change the offset the only thing you could do to widen them would be to use longer wheel studs and have some spacers machined.
/ widen rear tires #3
If they're R4 tires, solid centers welded to the rims, then no. These are out as far as they can go. I haven't seen the rims with ag tires to know if they can be unbolted as somguyss mentioned.
/ widen rear tires #4
One picture would help a lot:)
/ widen rear tires
They are R4 one piece. So I guess the answer is no.
thanks
/ widen rear tires #8
You also want to measure the offset on both the inside and outside of the wheel. If the offset is greater on the inside, swapping the wheels side to side might be worthwhile. Remember, R-4s are uni-directional, so it would have to be a side to side swap.
/ widen rear tires #9
Just browsing Bobcat's online catalog, lo & behold Bobcat shows a 2 piece rim for use on R4 & R1 tires on DK equivalent tractors.
20ft Shipping Container (A64047)
20ft Shipping...
2007 MACK CTP713 TRI AXLE DUMP TRUCK (A59575)
2007 MACK CTP713...
AUCTION STARTS HERE @ 9AM (A63291)
AUCTION STARTS...
2022 CATERPILLAR 299D3 XE SKID STEER (A64279)
2022 CATERPILLAR...
1137 (A63291)
1137 (A63291)
UNKNOWN  500BBL WHEELED FRAC TANK (A58214)
UNKNOWN 500BBL...
