Basic necessities to have with your tractor
/ Basic necessities to have with your tractor #1
breadtrk
ashland city, tn
XR 3037 HST Cab
I'm New to all of this.
What tools, safety equipment, or other stuff do you guys consider mandatory?
/ Basic necessities to have with your tractor #2
Gloves, adjustable wrench, BFH, extra pins, at a minimum.
/ Basic necessities to have with your tractor #3
Earplugs and eye protection. I have a Vice Grip and an adjustable wrench in the toolbox along with a few spare retainer pins.
/ Basic necessities to have with your tractor #4
I keep gloves, 20 psi tire gauge, and a couple of clean wipes on mine. The tools I keep on my service truck to prevent them from breaking the cab glass in rough fields.
/ Basic necessities to have with your tractor #5
Fire ext. Channel Locks, Duct tape, small coil of wire, Extra oil., Every thing else that was mentioned, and Common sence
/ Basic necessities to have with your tractor #6
Fencing pliers.
/ Basic necessities to have with your tractor #7
Extra shear bolts (with wrenches) for PTO driven attachments like mowers and post hole diggers.
/ Basic necessities to have with your tractor #8
Cell phone w/hopefully reception (in case of accident/stranded) and "baby wipes" ! ;)
/ Basic necessities to have with your tractor #9
This is sooooooo dependant on tractor use. I carry clampon cylinder stops, 3pt arm bushings, several hitch pins, extra set of 3pt clips, PTO shaft converter, 2 chainsaw chains, 1 chainsaw, 2 adjustable wrenches, fencing pliers, hammer, clevis, 3 log chains, extra 3pt top link, extra 3pt side link, bug spray, toilet paper, can coolie, cooler, prybar, tordon. I'm positive I missed something.....
/ Basic necessities to have with your tractor #10
You will make up your own must haves pretty quick. Whatever you find yourself driving back to the barn/shop/house for is a good start!
I don't carry a lot of tools. Invariably when something breaks/loosens etc, it's a trip back for the big tools anyways. Good maintenance lessens your need for tools while tractoring! Something to tighten up loose hose clamps can be handy and wire cutters.
Sunglasses, gloves, a few shop towels, grease, duct tape, a few bandages and cell phone about does it for me.
/ Basic necessities to have with your tractor #11
Depends on the use as stated. Pins and clips for the 3ph, clevis for the draw bar, vise grips and a small hammer, screw drivers flat and Philips. If you have the chains on then repair links and spare clevises to fit and enough of the above tools to make a repair sub zero without walking back to the house. I leave oil, antifreeze and grease gun where I park the tractor and top off before start and grease while it warms up. After that it depends on what your doing and what your hitched to. Haying and cutting wood call for different things at hand as would plowing or brush hogging. The tool box that came with mine is too small and I'm going to replace it but I don't want to get too big as it will become a clutter collector.
Clutter is what I'm trying to avoid. For me spare top and side links are in that category, I don't carry spare tie rod ends or u joints in my truck either.
I understand wrenches and cheap bolts for shear pins.
I also understand more detail of my use will help. I'm taking care of my own property, 1500ft drive, and reclaiming a field that hasn't been touched in 20 years. I'll also be doing wildlife plots for a few local and a couple distant lease properties.
/ Basic necessities to have with your tractor #13
There is also the tools you acquire to deal with the trouble you've had lately. For example last winter I had trouble with gelled fuel and waxed up fuel filters. You end up with anything you need other then your basic kit to solve the problem. In this case the little wrench that fits the bleed screws on the injector pump. Might as well leave it in the tractor tool box as that is where you are most likely to need it next.
/ Basic necessities to have with your tractor #14
grease gun, 3/4" socket set, large wrenches (OVER 1"), large crowbar, and torque wrench.
/ Basic necessities to have with your tractor #16
This is sooooooo dependant on tractor use. I carry clampon cylinder stops, 3pt arm bushings, several hitch pins, extra set of 3pt clips, PTO shaft converter, 2 chainsaw chains, 1 chainsaw, 2 adjustable wrenches, fencing pliers, hammer, clevis, 3 log chains, extra 3pt top link, extra 3pt side link, bug spray, toilet paper, can coolie, cooler, prybar, tordon. I'm positive I missed something.....[/QUOTE
Still some room left for you to sit after all this stuff on ? :laughing:
Black
/ Basic necessities to have with your tractor #17
Black
Seriously, where do you put that stuff? Two essentials for me: Coffee (till about 8 or 9am) and then water.
/ Basic necessities to have with your tractor #18
Very, very true. I use the small factory box, plus an additional box of similar size, plus an open topped box next to the seat to throw hitch pins, fencing pliers, often used items, plus a chain box just large enough to store 3 chains with a clevis thrown on top, plus a small open box on the inside of the fender to stick my cell phone and glass case so I don't break em in my pocket, plus a chainsaw scabbard.
Nothing more aggravating than digging thru a large container for the item wanted. It's alway, always on the bottom.
/ Basic necessities to have with your tractor #19
Organization my friends, organization. None of my containers limit my ability to operate and/or mount/dismount the tractor.If all you need to carry on your tractor is coffee, then you must just be putting around sightseeing???Here's the best pics I can find. I actually forgot about the cooler holder. So I don't hafta go back to the house for that water.....
/ Basic necessities to have with your tractor #20
I thought this thread would be informative and useful for readers. Also was anxious to see new ideas. Seems like most of the responses are negative toward those that volunteered information.
Before you negatively attack an item that someone is carrying you should reflect a moment. Would an operator carry something just to create "clutter"?? Would same operator carry something heavy and bulky that was not needed?? Probably not.
So with that said, wouldn't your above response have served everyone better if you simply asked why someone would carry an extra top link and side link??
:confused3:
2015 John Deere 332G Skid Steer w/ Bucket (A63688)
2015 John Deere...
2023 JOHN DEERE 450P LGP CRAWLER DOZER (A65053)
2023 JOHN DEERE...
Coleman Back Home Screen House (A62613)
Coleman Back Home...
2015 Peterbilt 337 Galbreath CH8000 Container Handler Truck (A64194)
2015 Peterbilt 337...
12' x 76" Tilt Trailer (A66285)
12' x 76" Tilt...
2000 Ford F-750 Debris Truck, VIN # 3FEXF75H8YMA01188 (A65563)
2000 Ford F-750...
