Basic necessities to have with your tractor
/ Basic necessities to have with your tractor #21
I thought this thread would be informative and useful for readers. Also was anxious to see new ideas. Seems like most of the responses are negative toward those that volunteered information.
Before you negatively attack an item that someone is carrying you should reflect a moment. Would an operator carry something just to create "clutter"?? Would same operator carry something heavy and bulky that was not needed?? Probably not.
So with that said, wouldn't your above response have served everyone better if you simply asked why someone would carry an extra top link and side link??
:confused3:
My question:) I enjoy seeing all the ideas but was lost on the spare top link. I bet there is something to learn there. I thought perhaps it is to deal with an assortment of cat 1 and cat 2 implements
/ Basic necessities to have with your tractor #22
I use TnT. My TnT does not have pilot lock valves. With a constant load the cylinders will eventually drift.
For the top link, I remove the cylinder and attach the solid top link if I'm pulling/carrying heavy loads using the top bar of my QH.
For the side link, I remove the cylinder and attach the solid side link when I'm using my mounted brush cutter so everything stays level.
My uses and equipment is scattered between two farms. Nothing more aggravating than needing to change links and one required being at the other location.....
Thanks for asking. :)
/ Basic necessities to have with your tractor #23
I never get too far from my barn so I usually carry more personal type stuff: sunscreen, water (drinking), sunhat, sunglasses, bugnet hat, scraper (mower deck clog), leather gloves (thistles 'n such), earplugs, sometimes a dust mask or respirator (if dry or allergy season). That's about it, I think.
I'm not gonna provide my winter list cause I'm sick of winter! :thumbsdown:
/ Basic necessities to have with your tractor #24
One thing I haven't seen mentioned that I always have on hand, is a tire plug kit. If you poke a hole in your loaded tires you want to do everything you can to keep the fluid in the tire.
/ Basic necessities to have with your tractor #25
Ovrszd, Just curious. what's with the extra battery up on the rear fender?
/ Basic necessities to have with your tractor #26
4lb hammer, spray can lube, draw pin, snap pin, bungee cord, small ~20' chain.
/ Basic necessities to have with your tractor #27
It is truly amazing what you can do out in the fields with a tractor if you arrive there with the right stuff.
/ Basic necessities to have with your tractor #28
Hmmm! Lets see. Shop towels to wipe off some of the dirt on my hands. Extra gloves - sometimes I play in the water and get really wet(allover). If I get wet all over - i.e. fall in - then its a trip home. Most of my extra tools, etc are carried on my implements. Extra locking pins on all implements and shear bolts for those that are pto driven. Crescent wrenches on those that have nuts/bolts that will need adjustment. I keep the required tools on my implements - in the op manual tube - because the "tool box" on my tractor is a joke. I've had it unlock on one of my rough trails and spill EVERYTHING out on the ground. I keep shop towels in the tool box now. And maybe a candy bar or two. And a pack of chewing gum. Actually, in the 32 years I've had a tractor I've never had to do field repairs or maintenance. I try to get all that maintenance stuff done at home and so far, have been quite successful. Take that back - had to install new shear bolts on my snow thrower when it tried to eat a wooden fence post or large rock.
:confused3:
Sorry you took offense to that. I was making light of your obvious overkill, as did a few others (maybe we are not the ones who need to reflect?). I'm 55 years old, don't need no lectures on how to behave, thank you.
Keeping the tools on the implement is brilliant. I've also seen a few really sharp chain saw scabbards around the board that give me some ideas. Searching has led me to use all the cool ideas I've seen for a carry all to construct the ultimate one. Reading everything I could find about clearing the field had made me realize I absolutely need some sort of brush cutter grabber tooth bar for my bucket.
Thanks for all the great ideas so far.
/ Basic necessities to have with your tractor #30
That's a cooler. My Son gave it to me several years ago. Looks just like a Delco battery huh. :)
/ Basic necessities to have with your tractor #31
That brings up an additional question. Anyone have a good toolbox that came on the tractor??? Pictures please??? I'm thinking it's like Bigfoot, some talk about it, but there's never any proof.... :p
/ Basic necessities to have with your tractor #32
I took no offense, just making a point. But then,,,, you did it again with the "obvious overkill" statement. How is it that you would know what items I listed that are not needed and thus "overkill"??? :confused3:
/ Basic necessities to have with your tractor #33
. The tool box that came with mine is too small and I'm going to replace it but I don't want to get too big as it will become a clutter collector.
Theres usually some room on the axle housing just inside the rears. Lo and out of the way.
/ Basic necessities to have with your tractor #35
Are you suggesting between the tires and the fender vertical wall? If so the chains in winter and the branches they sometimes pick up for a turn or so would wipe it out. The 50xx E or D series is assembled in India. The ones they sell there have a seat on the fender for the Mother -in-law. OSHA says you can't risk that here hence the tiny toolbox which real design function is to make it impossible to ride on the fender. Mine has flat topped fenders with room for a box equal to two or three milk crates end to end. It is a bit high up even for me so a tall box would be hard to see into so I'm thinking a box the length and width of the flat fender surface that is no more then eight inches high or one that has a side door to let you see the bottom without climbing on the rear tire. The other fender may become a modified milk crate(s) that will serve as a chain saw scabbard and oil ,gas and falling wedge holder.
/ Basic necessities to have with your tractor #36
I have marked the nut & bolt sizes clearly in marker on anything I have to remove or tighten (I'm terrible at guesstimating size). I carry open end wrenches for the implements I'm going to use that day. Shear pins are a must for me as is a cell phone.
<<< He is a Fox Red Lab for those who have asked :)
/ Basic necessities to have with your tractor #37
Are you suggesting between the tires and the fender vertical wall? If so the chains in winter and the branches they sometimes pick up for a turn or so would wipe it out. .
With 30" wheels no problem. A narrow setting would not work. Wide setting is fine.
larry
/ Basic necessities to have with your tractor #38
Good idea. I might put some sidecutters in my bush hog tube for when I get tangled up in rope or fencing.
/ Basic necessities to have with your tractor #39
Yea :laughing: I just went back and took another look and see its a cooler, good one :thumbsup:
/ Basic necessities to have with your tractor #40
As for Larry's suggested location on the axle housing. Some tractors have room there but it's not gonna be a CUT or small Utility tractor.
I like your first idea of a box the length/width of the fender with short side.
Personally, I would not like the opening on the side. Something will fall out every time you open it. And the item you desire will always be in the back.
Make sure you start a thread and post up some pics when you get it built. I"m always on the lookout for new ideas. :)
Denyo DCA-600SPK 500kW Sound-Attenuated Diesel Generator (A63689)
Denyo DCA-600SPK...
2007 Ford F-750 Water Truck w 2,000 Gallon Tank (A63689)
2007 Ford F-750...
(2) John Deere Row Markers (A64127)
(2) John Deere Row...
2016 Caterpillar 304E2 (A64126)
2016 Caterpillar...
2016 Kia Forte Sedan (A61574)
2016 Kia Forte...
New/Unused Wolverine 72in Quick Attach Brush Cutter (A65583)
New/Unused...
