JD D130 won't start
/ JD D130 won't start #1
stuinnh
Derry, NH
JD D130
My D130 turns over and lights work but won't start. It was running, then it wasn't. New plugs gas and oil filter. New air filters. Charged battery. Has gas........
Help!
Stu
/ JD D130 won't start #2
First of all listen for the click of the solenoid on the bottom of the carb bowl. If that is working, Then next spray some carb cleaner in the carb. It should start. I'm sure it isn't spark related because it is a twin cylinder with independent coils. If it starts with the cleaner then dies, it is probably a dirty carb from the ethanol in the gas sitting there. Probably have to pull the bowl at the least to clean it.
Hi!
When should I hear the solenoid? When I turn key or when it's cranking? Tractor is only 2 years old.......
thanx
/ JD D130 won't start #4
You should here it right when you turn the key, before you crank ot over.
43023 (A59228)
43023 (A59228)
2013 John Deere 1790 Planter (A63109)
2013 John Deere...
2000 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2000 Bobcat 863...
(3) 31'X52' BULL FLEX HAY TARPS (A62131)
(3) 31'X52' BULL...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A63118)
PENDING SELLER...
New/Unused 7ft Fork Extension (A61166)
New/Unused 7ft...
