X595 harder to start.
/ X595 harder to start. #1
dieselram
Gold Member
Meadville, PA
2007 John Deere 3120 TLBM
I just bought an 04 X595. When its a little cooler it takes awhile to start. I checked with a test light to see if I had juice to the glow plugs. This morning it did now it doesnt. Do they cycle on everytime the key is turned on no matter the outside or engine temp? It cranks and puffs white smoke for about 5 seconds before it fires and its not even that cold out. It only has 540 hours on it. Once it fires the first time it seems to fire rather quickly after that. Even if you get it started cold shut it right off before it warms up then try it again and it fires right away. I did just change the fuel filter which JD gave me the wrong (long) one the first time. Now I have the correct shorter one in it. Guys check this out when you are at the dealer because there are 2 different filters depending on if you have the 74 or 76 engine. Seemed fine before the fiter change but I changed it an hour after I bought it. Maybe the previous owner knew of this problem and was starting it before I got there to look at it the few times I went to check it out. I would think it should put power to the glow plug bank each time the key is turned on no matter what. I don't have a tech manual for it, I do have one for my old X485 but thats gas so it does me no good. Please help me get this figured out because i'm sure it will be dead in the water if it gets cold out. All this is happening when its 40-60 outside temp.
/ X595 harder to start. #2
There is a glow plug relay sometimes called glow plug timer . It is under the dash it is like a little box . The reason the light doesn't come on all the time after you start it or cycle the switch it measures the resistance of the glow plugs. After it cools down the resistance goes down and will cycle the glow plugs again. And there is also a temperature sensor that is in the water jacket on the head that helps control the glow plug cycle
The light on the dash does come on everytime but now I am not getting any power to the plugs when they are supposed to be in their cycle. Its a big white wire .180 in dia that puts power to the first plug then a jumper goes to the other 2. I think I traced that wire to a relay on the right hand side-the single one below the 2 on top that are easier visible. I stuck my test light up in there and im not getting any power there either. Is that a relay that needs replaced? What else do I do to diagnose this?
So I go out this morning and give it a shot and what do you know there is power to the plugs (checked with a test light) and it fires up with ease after I wait for the test light to go out which is awhile after the dash light goes out. What gives here?
/ X595 harder to start. #5
Check your wires to make sure they are not in bad shape and ground . The glow plugs stay on for a little bit after the light goes out to help control smoke on a cold engine. E.P.A requirement for emissions
Seems to be an intermittent thing. I check it the same place. Sometimes they work sometimes they don't. Could it be the relay or the glow plug controller? Do they cycle every time regardless of the temp?
/ X595 harder to start. #7
It sounds like glow plug controller.they should not cycle after the engine is up to temp
What about the relay? Do glow plug controllers do that-work intermittently?
/ X595 harder to start. #9
The glow plugs DO cycle every time regardless of temp (with this model). It certainly could be the relay, or the controller, but I would focus on the high amperage side of the circuit...not the controller- Yet.
Things like this usually fail "where the rubber meets the road" So, the relay, grounds and connections to the glow plugs would be where I would go.
Do you have a volt meter? If so, all of these things can be quickly ruled out when it is acting up.
I do have a volt meter but kinda dumb using it. Can you guide me through the process to rule things out?
/ X595 harder to start. #11
When you cycle the glow plugs try to isolate the problem to the power side of the circuit or the control side of the circuit. Use your volt meter to determine if the relay coil is getting a 12 volt "signal" from the control board to "suck it in". If the relay is pulling in, check for 12 volts on the input side of the power contacts. Just follow the circuit all the way through. Keep the meter black lead planted on ground. You should probably get a service manual so you would have a wiring diagram. I could post a couple of pages from my X748 manual, but they made some changes , so I don't know if it would be accurate for a X595.
Not sure how to trace those down. There are a few wires going into what I think is the glow plug relay (big white wire running into it from the glow plugs I think) I'm no electrical guru. Where should I check it and what should it be doing. I wish somebody with a 495 or 595 had the same issues.
I looked on JD parts and it lists 3 relays (AT75769) they all appear to be the same because they are all the same part number. Is a relay just a relay? Can I get one at an auto parts store because it seems generic-not specific.
/ X595 harder to start. #14
Yes, you can. Take the old one with you because the coil might have a resistor, or a diode across the coil for suppression. Or it might have no suppression. Get the same thing.
Get a shop manual too.
Ok I pulled the relay which I think controls the glow plugs. Has 4 wires to it. A big fat red one, a fat white one and 2 small diameter wires-a yellow and a blue. I checked for power at the harness and the only one that powers up when you turn the key on is the small diameter yellow one. Shouldnt the big one have power? I did this check with the relay pulled. I checked it at the plug.
Id hate to spend the money on a shop manual when I think I am trading it on a new machine. i just want to make it right before I trade it in.
/ X595 harder to start. #19
I understand. I can only do one more thing to try to help:
HERE IS A LINK to a thread of a guy with a 495, that I was trying to help a while back. His problem was like yours. He ended up buying a repair manual, and fixed his problem. You could try PM'ing him for some details on the manual.
Good luck, and poast back when you fix it.
Ok got it fixed. Turns out the fusible link had a break in it!
