Ballasting calculations
/ Ballasting calculations
Hmmmm. I gotta admit, that excel program is probably what I was looking for. There is a second page to this - it is a page where you collect, compute & log all the variables. Once page two is finished then by substitution into correct areas of page one you can come up with an answer. I know from experience that just going out, firing up the tractor and lifting things of varying weights, you will come up with a supremely correct answer a lot sooner. It took me over a week to figure out the entire situation. It was only because my son looked at it and understood it and told me I was correct that I knew that I had stumbled into the answer. Thanks for looking, finding & posting GManBart.
/ Ballasting calculations #24
Simple rule of thumb is 1-1.5x the loader lift capacity as ballast. Split between the tire fill, wheel weights and 3pt. About 1/2 of the ballast on the 3pt. That will at least get you close.
As others have said, the task impacts the ballast amount and location. A full loader will lighten the rear tires, where a bottom plow or big disc will lighten the front. Fer example... My TLB has a 5000 pound loader lift to full height. Filled tires add about 600# (partial filled), wheel weights add 1200# and the hoe is over 3000 pounds. That's essentially the same as the lift capacity, and it's still light in the rear with a full bucket due to geometry. This shows up when filling a front bucket and having to back up a hill. Flat out, it don't! Why? The front weight is farther out front than the rear weight is out back, so it teeter-totter's around the front axle. But after dumping the bucket, backing down a hill is scary as the front gets light! Just can't be perfect for all things all the time!
Thanks john_bud,
I was hoping there was a general rule of thumb. I don't think I have enough brain power to try that excel spread sheet again. I have 1500# of rim guard and 710# of roll over box blade. - I took off the rear blade as it was only 565#. This will get me started and if it gets light I'll just add to the 3-point.
2013 FORD E-350 11 PASSENGER VAN (A65643)
2013 FORD E-350 11...
Ditch Witch 6510 DD Trencher 4x4 (A62613)
Ditch Witch 6510...
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
Atspower Mini Excavator (A60352)
Atspower Mini...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
2022 EZ-GO ELITE...
