All hydraulic post driver
/ All hydraulic post driver #1
Verticaltrx
VA
Kubota B3200/L2501/SVL65-2/U35-4, IH 454/656, Ford NAA, Case 1845C/480E/450C LGP
After a couple years hiatus I'm finally getting back to finishing a post driver I've been working on. I'm a farmer and fencing contractor so I've run several different model drivers and tried to make something a little different that suits my needs. The design criteria was that it would be light enough to use with a compact tractor, powerful enough for driving 6-7" posts in most conditions, and easy to keep a post plumb. I roughly modeled it after some of the New Zealand and European designs which I like much better than the American designs.
The completed unit should weigh about 800lbs and the driving weight is ~450lbs. At max height there is a little over 10' between the weight and the ground. The weight has 8' of travel and is carried low for maximum stability on small tractors. Front to back and side to side tilt is all hydraulic. I used a 2" bore, 24" stroke and a 4:1 pulley arrangement to get maximum travel and free-fall speed on the weight. There is also a post cap that will securely hold the top of the post as it is being driven to assure it is plumb (not installed yet.)
I just assembled it for the first time yesterday and the initial tests are promising. All the hydraulics function as the should, the weight drops with a lot of force, and it seems to drive a post as well as most other drivers I've used. I've got a bunch of little things to finish up like greaseable pins for the pulleys, swapping out some bolts, adding a way to lift the post cap, paint, etc.
Here are the only two pics I have so far:
/ All hydraulic post driver #2
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=370077"/>
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=370078"/>
Nice. More pictures please.
/ All hydraulic post driver #3
looks like a good simple design, let us know how you like it and how it works,
Sorry, no more pics yet. I took the camera with me but realized I forgot the memory card in the computer.
I've run into a bit of a snag with my design. I calculated the cylinder to be able to lift the weight, but neglected to factor in the weight of the post cap. It raises the weight just fine, but raising the 40lb post cap is too much. I might try to check some pressures, but I think the cylinder just can't do it.
Looks like I'll have to make a lighter weight post cap.
/ All hydraulic post driver #5
Get a bigger cylinder. Lighter cap will just crack, bend, smash, whatever. 40lbs isn't stalling the hydro brother.
/ All hydraulic post driver #6
Funny you say that I have the same problem My design is such that I can work around it easily, and all I have to do is to push it up and it is enough to allow it all to lift, and I have a telescoping mast, that I can lift it as well and set on the post and then reposition the unit to drive the post, If I would tweak the pressure on the tractor, just a few lb's I am sure it would lift it all, I am guessing that I am short less than 20 pounds on the final lift.
/ All hydraulic post driver #7
Cool setup. Looking forward to seeing more. Can you crank up the PSI a bit for the extra few pounds or is it maxed for the cylinder? Seems like your valve is going into bypass.
/ All hydraulic post driver #8
Great project. How do you release the weight for free fall?
/ All hydraulic post driver #9
On the one hydraulic post driver I messed with(commercially available model) the biggest concern with it was getting rid of the oil out of the cylinder fast enough so it would free-fall. It required a huge hose and a special port had to be installed in the hydraulic tank on the skidsteer to handle the volume of oil from the cylinder. It looks to me like a bigger cylinder would compound this problem, more oil to get rid of.
A bigger cylinder wont work. I need the smallest cylinder possible otherwise the amount of fluid that has to be displaced is too much and it can't free fall. I'm already having to use a 3/4" hydraulic line between the valve (21gpm valve) and the cylinder and a 1" return line to the tractor tank. There is only so much fluid that you can move. The only option if I went to a bigger cylinder is to step up to a 30-40gpm valve and much bigger lines which would be very expensive.
I looked at your thread a while back and noticed a lot of similarities between our designs. Mine actually will lift the current post cap, but the tractor has to be at max throttle and you have to quickly pull the hydraulic lever to get a quick burst to lift it. Even then sometimes it opens the relief valve before it's all the way up. I'm thinking a lighter post cap will either a)be easy enough for the hydraulics to lift or b)be easy enough to push it up by hand using the top of the post.
I'm going to hook up a pressure gauge to the tractor remotes and the valve on the post driver to see what it's actually at before I do anything else. The valve 'should' be set at 2500psi and the tractor should be a little higher than that.
The lever to raise the weight also drops it. Push the lever forward and the weight goes up, pull it back and it comes down. If you pull it back just a little the weight will descend as slow as you want. Pull it quickly all the way back and it free-falls, basically the same as any post driver.
/ All hydraulic post driver #11
the cylinder I have had a very small port in it, and I welded a larger fitting on over the port area of the cylinder as not to restrict, the oil any more, and it seems to work very nicely, again I used the smallest cylinder I thought that would work,
(I do not remember for sure but I think the port was either 1/4", and I welded on a fitting so I could use a 3/4" hose), so the hose inside diameter was larger than the port, and ended up wing stacked valves, with #8 SAE ports, and the valve does not seem to have any real restriction in it, when pushed clear open,
/ All hydraulic post driver #12
Is there an advantage to the hydraulic style post drivers? I see possibly more control by using the valve lever to control the speed of the cylinder. But other than that, all you are doing is raising a heavy weight up and letting gravity do the work.
The reason I ask, I watched a older design post driver work, it was driven with a small driveshaft off the pto. It had a small gearbox and a couple of chains if i remember correctly. All it had was a large solid rubber tire that turned slowly all the time from the pto system. It had a large piece of metal that ran up and down in a track made into another vertical piece. I don't remember all the details but basically you had a lever that applied the rubber wheel to the metal piece to lift it up and when it got to the top you pulled the wheel away from it and it was free to fall on top of the post. It was a well thought piece, very old, and still worked well.
P.S. I just thought of another advantage to the hydraulic system; You could put the driver in a custom position easier than the pto driven unit. I guess most of the front mounted drivers are probably hydraulic.
KMC Hi-Residue Plow (A64127)
KMC Hi-Residue...
International MaxxForce 6-Cylinder Turbo Diesel Engine with Transmission (A59228)
International...
2017 Ford F-150 Ext. Cab Pickup Truck (A61572)
2017 Ford F-150...
20' Reids Trailer (A62613)
20' Reids Trailer...
2001 WORKHORSE CONVERTED TO FOOD TRUCK (A59914)
2001 WORKHORSE...
2021 JOHN DEERE 331G SKID STEER (A62129)
2021 JOHN DEERE...
