jimoxdrover
I cannot get the three point hitch to go down = the one lever on the dash is stuck - how do I fix?
			Long story short, you buy a new cable and replace it.
I have more time for a longer response now. The cable goes from under the dash on the left side under the floor board that's over the battery's and the transmission to the right side where under some hydraulic lines it moves a small lever that goes into the three point hitch housing over the transmission. I'm pretty sure the problem is your cable but if oyu want to check take the pin out on the lever that goes into the three point hitch housing and move it. If you can get the three point to rise and fall with that small lever then the cable is for sure at fault. It's more of a time consuming job than a difficult one to change the cable. It's 4 bolts and lift the seat all the way up to remove the floor board and that sure makes the job a lot simpler. It's also a lot easier if you don't have a cab.
