3 point problems
/ 3 point problems #1
xmariner
Bushnell, FL
LS XR4155HC
I hope someone here can lead me in the right direction for what I consider to be an inexcusable problem. Brandy new XR4040C straight from North Carolina. The problem: with nothing attached to the 3 pt hitch it raises and lowers as you would expect, however attach an implement with some weight and raising said implement shakes the entire tractor. It's as though the weight limitation has been met or exceeded.
Here's the "hitch" - if the tractor is in motion (above idling rpm) then the jerky positioning (raising only) calms down some.
So far the dealership is stumped and has elevated the matter to a regional tech with LS. Haven't heard from him (her) yet.
We've played with the control for lowering speed, moved the draft control from forward to aft and vice versa, changed the top link from the middle hole (on the tractor) to the bottom with no change. I even removed the top link all together which as you might guess made no difference.
I checked the hydraulic fluid level today and it is about 1/3 between low and full. The loader works well just a little slow compared to my R3039.
I know time is money and who am I to tell LS or anyone else for that matter how to run their business but would it throw production a curve to actually load test the loaders and 3 points before shipping?
If I was talking about the R3039 I would still gripe but would load it on the trailer and take it to the dealer if required. But the XR4040C exceeds the load rating of my trailer so now I'll have to pay someone to transport it if necessary. (blah blah)
Any ideas would be greatly appreciated.
/ 3 point problems #2
They should send someone to you.
/ 3 point problems #3
Can't help with the jerky 3 pt. but wondered what size trailer do you have? the xr4040c w/ loader only weighs 5430 not counting filled tires or implements. That's about max for a 7K trailer.
/ 3 point problems
I agree with you "they" should send someone to my place - I mean really, right out of the box and it doesn't work properly. But I doubt that'll happen. The dealer is only 30 min away.
My trailer is aluminum - very nice but even though it has a pair of 3500 lb. axles it is down rated to 6000 lbs. because of the aluminum. The rear tires are loaded adding another 500 lbs. so I'm told.
/ 3 point problems #5
I guarantee you that my dealer in Colorado would be there making a house call! I found a small antifreeze leak, can't figure out where it's coming from unless the tech spilled some when he installed the block heater and I don't have a cooling system pressure tester for that small of radiator neck, my dealer said no problem and ordered a new radiator just to be sure we didn't have a problem and told me that he would pick it up for warranty repair.....he's 75 miles one way from me! Needless to say, I've already sent him some business!,
/ 3 point problems #6
They will come to you. Or they better had.
Might be air in the hydraulic system.
/ 3 point problems #7
If the hydraulic fluid level is 1/3 between low and full, have you tried topping it off?
For Sale - Brush Hog - Woods RCC42 rotary cutter
For Sale - Brush...
Volvo 10ft Loader Rake Attachment (A64553)
Volvo 10ft Loader...
2015 Ford Taurus Sedan (A64557)
2015 Ford Taurus...
2022 EZ-GO ELITE...
2019 CATERPILLAR 279D SKID STEER (A65053)
2019 CATERPILLAR...
2014 Kawasaki 70Z7 Articulated Wheel Loader (A64553)
2014 Kawasaki 70Z7...
