Backhoe float
/ Backhoe float #1
jel1988
Gold Member
Elliot Lake, ON
2012 Mahindra Max 22, John Deere D120
What does the float on a backhoe do? How is it used?
/ Backhoe float #2
My backhoe has no float on the hoe. The Front loader has a float setting. is that what you mean?
More details on the question would be helpful.
/ Backhoe float #3
If it like the Woods backhoes, it is a safety feature on the boom circuit to keep from getting crushed if something breaks.
/ Backhoe float #4
The BH float is used to do the final smoothing at the bottom of the trench.
Set the bottom of the bucket flat, then put it in float, it won't dig in, just scrape.
/ Backhoe float #5
Mine doesn't have float but if I do crowd and lift at the same time I get the same effect and I can trim the curl as it comes in. Mine's an old 4-lever so I just pull the 2 left levers in together.
2016 WEILER P385A ASPHALT PAVER (A63276)
2016 WEILER P385A...
John Deere 2210 Field Cultivator 43' (A63688)
John Deere 2210...
2005 Peterbilt 379 Extended Day Cab (A62613)
2005 Peterbilt 379...
2008 PETERBILT 365 (A65643)
2008 PETERBILT 365...
2011 MACLTT  150 BBL ALUMINUM VACUUM TRAILER (A65643)
2011 MACLTT 150...
2018 Mahindra Mpact XTV1000S (A64127)
2018 Mahindra...
