Throttle Cable
/ Throttle Cable #1
Frank Sorbello
Gold Member
Power Trac PT-422
How hard is it to replace the throttle cable on a PT 422? And is there an aftermarket one vs Power Trac?
Thanks
Frank
/ Throttle Cable
Looking to replace my throttle cable. Does anyone have a part number or size of the cable?
/ Throttle Cable #3
I replaced it on my 1430 in less than 45 minutes. It was sticking when the temperature dropped below 30, which was a big deal last winter in Wisconsin. I was worried about snaking it through tunnel from the front half to the back half, but it was very simple. There are access panels that are easily removed so I could push it straight through. The toughest part was straightening out the s bend at the engine end so I could attach it to the throttle lever on the engine. I was able to move the dash enough to get at the throttle bolts without disconnecting anything.
Bill
/ Throttle Cable #5
Bill
Hi Bill,
Do you happen to know the length of that cable? (Maybe you didn't need to think about it if you ordered from PT.) Thank-you in advance.
My throttle cable 'died' today. Since it is attached at both ends, I presume the cable broke/separated inside the housing/sheathing. (I've never seen this on any machine...!!) It could very well be that, somewhere along the line, after ten years, the sheathing wore out from vibrations/rubbing, and the cable eventually also did so.
I'll find out when I pull it out, which I'll do when I have a replacement in my hands. If I'm not going to buy from PT, I need to know the length...
I'm happy to upgrade the quality, if that can be done.
/ Throttle Cable #6
So, I decided to remove the throttle cable to measure it. That way, I could contemplate a non-PT part...
I started by detaching cable at engine, since it seems the easiest way to remove would be by pulling out from the dash. Once everything was unbolted at the engine, the cable/core was free to be pulled out. I was surprised to find out the cable had broken only 4.5in away from its end...??!! Pretty clean cut; no signs of wear/chaffing/rubbing. A bit surprising/bizarre.
I realized that the cable's routing is longer than it needs to be to reach the engine. Presumably, to avoid engine heat. I thought rerouting cable on a shorter path might give me a temporary solution that might make up the 4.5in that was lost.
I removed 4.5in of sheathing and rerouted the cable; it worked. However, the cable now runs below the oil pan, where it will be exposed to a lot more heat... Time will tell...
I'll still inquire from PT about the cost for a replacement. I also thought of replacing and relocating throttle with a much shorter length that does not run through tunnel. As long as one hand can easily reach a lever from the tractor's seat, the lever does not need to be in the dash... Anyone MacGiver'ed something like that...?
/ Throttle Cable #7
Congratulations on getting it working.
Universal throttle cables are pretty easy to find and pretty cheap, if the PT turns out to be an issue.
I wouldn't reroute the throttle cable, but that is me. I think anywhere that is not routed through the tunnel is likely to be awkward, and hard to use quickly in case of an emergency.
All the best,
Peter
/ Throttle Cable #8
I though about just putting the throttle and choke at the engine, but decided to just replace the throttle and choke cables because they were pretty reasonable price from PT, and the cost of a throttle/choke panel for the Kohler was almost the same as the two cables.
The hardest part of changing them for me was that they were zip tied inside the tunnel. Once I figured that out, easy peasy. I just tied a pull string to them so that I could use that to pull the new ones in.
/ Throttle Cable #9
Tested today; it's working.
However, an annoyance before my cable broke is still there, and worse... I'll post a new thread about that; I think it's Deutz-specific.
The Deutz engine appears to have an internal spring on its throttle lever, that sends the throttle to low idle by default. Makes sense. However, it seems that the strength of that spring overcomes the throttle cable, thus always reducing the RPMs. The throttle lever in the dash never stays at full RPMs; I have to hold it there with my thumb.
/ Throttle Cable #10
Should be a friction adjustment at the dash lever.
/ Throttle Cable #11
Yeah; I need to take a 2nd look at that... When the cable was disconnected at the engine (thus leaving the dash lever to move freely), it wasn't moving all that freely. There is a decent amount of resitance there.
I'll see about the possibility of tightening that some more, and see if I can achieve a desired outcome. Thx!
/ Throttle Cable #12
There is a friction nut in there. On my 1445, it is accessible (just) from underneath, and you can peer into the slot in the dash to see what you are doing.
My throttle lever got sticky, so I lubed it, and then it wouldn't hold the rpms until I adjusted the friction plate/nut.
All the best, Peter
/ Throttle Cable #13
BTW: the Deutz "spring" is just the governor doing its thing.
All the best,
Peter
/ Throttle Cable #14
So, I took a 2nd look at the friction adjustment. I was able to (just) reach a 7/16" nut. I turned it (about) 1/2 a turn, and it was too much! Settled on 3/8 of a turn for now, but it seems like another 1/16 of a turn would be best. (These are relative 'by feel' specs!)
Anyhow, I was pleasantly surprised by the results even if not perfect. I really didn't think playing with that nut would do much for me, especially since it was far from loose.
Thanks for the advice!!
/ Throttle Cable #15
That's great!
Yes, it doesn't take much, does it? After tightening, my experience is that it loosens up a little, perhaps due to irregularities in the plate getting worked smoother?
All the best,
Peter
JOHN DEERE BRAND E-Z FLO PULL TYPE DISTRIBUTOR (A63745)
JOHN DEERE BRAND...
2017 Cadillac Federal 70 IN Limo - 30,529 Miles w Premium Coachwork by Federal (A63118)
2017 Cadillac...
7102 (A61567)
7102 (A61567)
iDrive TDS-2010H...
YALE VERACITOR 50VX STRAIGHT MAST FORKLIFT (A63276)
YALE VERACITOR...
2012 VOLVO VNL64T630 6X4 T/A  SLEEPER TRUCK TRACTOR (A59910)
2012 VOLVO...
