Estimate the Weight of this log
   / Estimate the Weight of this log #11
I can see this competition is heating up, I revise my estimate to:
(((9" x 9") x pi) x 348") / 1728) x 62 lbs or exactly 2.7e+2st stone
   / Estimate the Weight of this log #13
Unlike electric motors, logs lose a lot of weight when you let the smoke out.
...though they seem to lose equal percentages in value, lol
   / Estimate the Weight of this log #14
2168# dry, or 3027# wet.
Thanks for all the replies. I also used the Woodweb calculator. I was curious to see what you guys came up with. Yes I did lift it with the tractor. I may have been able to lift a little more. With grapple weighing around 450lb, the SSQA on the loader @ 100lb, and the log at 3625 I was lifting 4175lbs.
Don't try this at home:laughing:
   / Estimate the Weight of this log #18
The ol' Kubby looks a might light in the loafers at the rear end, and a tad heavy at the front.:eek:
I wouldn't want to load the front axle up like that very often.:dollarsign:
   / Estimate the Weight of this log #19
My l5460 sure is alot more stable with weight up front when I have my #1100 BB on the rear. Easy to lift a rear wheel off the ground otherwise if too agressive while turning, esp on lumpy ground.
Excellent. Now I know what mine is capable of.
The loader on these tractors is pretty strong.
I don't think my l5460 could lift that.
Did you ever check to see were your relief is set?
This was pretty much a one time deal. I wanted to see what it would do.
I need a better ballast especially for use with the grapple. I want a compact but heavy ballast. I have a pretty cool idea for a ballast but I found the stuff to make it but IDK if the place will sell it to me. I may end up making a concrete ballast.
NEW Wolverine 72in Skid Steer Tiller (A59000)
NEW Wolverine 72in...
1294 (A58374)
1294 (A58374)
JOHN DEERE 1560 - 15' NO TILL GRAIN DRILL (A52708)
JOHN DEERE 1560 -...
toro reel master (A56857)
toro reel master...
CATERPILLAR CB-224C DOUBLE DRUM ROLLER (A52707)
CATERPILLAR...
LOT: (10) Chairs (A59076)
LOT: (10) Chairs...
