Turn an old truck into a tractor????
/ Turn an old truck into a tractor???? #22
I have seen where they take the engine and transmission from a FWD car (older Honda 1.5L and 1.6L engines are popular) and hook its driveshafts to the axles from a 4x4 or AWD vehicle. Instant 3 or 4 to 1 gear reduction.
Search for "transaxle buggy" to find some.
Aaron Z
About 15 years ago I took a night course in the truck repair department of the local community college. At that time the day students were building a miniature log forwarder like that using the drivetrain from a VW diesel and shortened Dana 60 axles. Nifty little rig.
/ Turn an old truck into a tractor???? #23
I've thought of making a machine that way a few years down the road.
Set it up with hydraulics, a 5'x5' dump bed, a rear PTO, hookups for a front snowplow and enough ground clearance to rake hay. Then I could safely take my daughters out to tedd hay with me...
Aaron Z
/ Turn an old truck into a tractor???? #24
It's easy to do and they work well but no 3pt hitch without a lot of work. For the wheels you can often find bolt pattern adaptors, have them made or re-drill the wheel centers to the new pattern. You can also replace the wheel centers. I have done all three of these and it's no big deal.
Building your own tractor is a very admirable task.
/ Turn an old truck into a tractor???? #25
Why would a 3 point be a lot of work? 2 lower arms tied to the lower frame, 2 cylinders to raise them (on separate spools to allow tilt) and a center bracket for the toplink.
If you only wanted to use one spool, you could use a rotary flow divider but it would probably cost as much as another spool.
PTO would likely be a pain in the butt though...
Aaron Z
/ Turn an old truck into a tractor???? #26
Aaron Z
Just the engineering aspect of it. PTO could be hydraulic and probably easy.
/ Turn an old truck into a tractor???? #29
I am thinking of using my K30 mud truck to skid logs with... our 117 ac of hillside has quite a few trees worth selling or milling, but my lil JD 3005 ain't gonna cut it pulling a log outta the woods up hill that weighs as much as it does. 7500 lb one ton truck with 40" mud tires and a winch in the back might do the trick. It has been the tow truck at the local mud holes for years, bet it can tow logs too!
/ Turn an old truck into a tractor???? #30
Thinking of finding a old hydraulic mower with a multi-section pump. One section for steering, one for remotes and the last for PTO (hydraulic or a 540 RPM shaft).
Aaron Z
2005 Komatsu HM-400 (A60462)
2005 Komatsu...
Caterpillar 2PD5000 5,000LB Diesel Forklift (A56857)
Caterpillar...
JOHN DEERE 5403 TRACTOR (A58375)
JOHN DEERE 5403...
2007 Ford F750 Bucket Truck (A60352)
2007 Ford F750...
Kubota U55-4 (A57148)
207281 (A52708)
207281 (A52708)
