Turn an old truck into a tractor????
/ Turn an old truck into a tractor???? #22
I have seen where they take the engine and transmission from a FWD car (older Honda 1.5L and 1.6L engines are popular) and hook its driveshafts to the axles from a 4x4 or AWD vehicle. Instant 3 or 4 to 1 gear reduction.
Search for "transaxle buggy" to find some.
Aaron Z
About 15 years ago I took a night course in the truck repair department of the local community college. At that time the day students were building a miniature log forwarder like that using the drivetrain from a VW diesel and shortened Dana 60 axles. Nifty little rig.
/ Turn an old truck into a tractor???? #23
I've thought of making a machine that way a few years down the road.
Set it up with hydraulics, a 5'x5' dump bed, a rear PTO, hookups for a front snowplow and enough ground clearance to rake hay. Then I could safely take my daughters out to tedd hay with me...
Aaron Z
/ Turn an old truck into a tractor???? #24
It's easy to do and they work well but no 3pt hitch without a lot of work. For the wheels you can often find bolt pattern adaptors, have them made or re-drill the wheel centers to the new pattern. You can also replace the wheel centers. I have done all three of these and it's no big deal.
Building your own tractor is a very admirable task.
/ Turn an old truck into a tractor???? #25
Why would a 3 point be a lot of work? 2 lower arms tied to the lower frame, 2 cylinders to raise them (on separate spools to allow tilt) and a center bracket for the toplink.
If you only wanted to use one spool, you could use a rotary flow divider but it would probably cost as much as another spool.
PTO would likely be a pain in the butt though...
Aaron Z
/ Turn an old truck into a tractor???? #26
Aaron Z
Just the engineering aspect of it. PTO could be hydraulic and probably easy.
/ Turn an old truck into a tractor???? #29
I am thinking of using my K30 mud truck to skid logs with... our 117 ac of hillside has quite a few trees worth selling or milling, but my lil JD 3005 ain't gonna cut it pulling a log outta the woods up hill that weighs as much as it does. 7500 lb one ton truck with 40" mud tires and a winch in the back might do the trick. It has been the tow truck at the local mud holes for years, bet it can tow logs too!
/ Turn an old truck into a tractor???? #30
Thinking of finding a old hydraulic mower with a multi-section pump. One section for steering, one for remotes and the last for PTO (hydraulic or a 540 RPM shaft).
Aaron Z
2014 Tesla Model S 60 Hatchback (A59231)
2014 Tesla Model S...
UNUSED SDLANCH SDLWC WOOD CHIPPER (A60432)
UNUSED SDLANCH...
2014 Freightliner Bucket Truck (A56438)
2014 Freightliner...
2016 PETERBILT 365 TANDEM AXLE DUMP TRUCK (A59905)
2016 PETERBILT 365...
2024 CUB CADET ULTIMA ZT1-54 ZERO TURN LAWNMOWER (A60430)
2024 CUB CADET...
2019 John Deere 310L EP Backhoe (A53485)
2019 John Deere...
