PTO issue U5030
   / PTO issue U5030 #1
PatMcD
Maine
LS U5030
Was out this morning on the new U5030 and had a problem. I'm still playing around with all the features and pushing all the buttons.
I have my logging winch on the back for a little ballast weight. I turned on the pto switch, it turned for about 5-10 seconds then stopped and the transmission oil pressure light came on. Pto light was still on. Did it both in auto and manual mode numerous times.
It was chilly this morning but not cold (20F). The tractor was running for about 15 minutes.
Also, this unit does not have the pro gear lever on the left side (the 540-750-1000 range lever). There is a covered spot where it obviously goes, but no lever.
Calling dealer tomorrow.
   / PTO issue U5030 #2
Do you know if the PTO was spinning?
   / PTO issue U5030
Yes. It will spin for 5-10 seconds and then stop as the pressure light comes on.
And to answer the next question: yes, the fluids are topped off.
   / PTO issue U5030 #4
I believe it's fine and many people will argue that 20 is cold, not chilly! :laughing: Mine will do the same thing until it's warmed up. I was told there is a very fine screen in there that slows the flow enough for the warning light to come on.
I let mine warm up for 15-20 minutes, go back out and turn the heater on and come in and post something snarky on TBN about how my rake style grapple is the best or those Green tractors are overpriced. Another 15-20 minutes later she's good to go! This only happens when it's chilly........
   / PTO issue U5030 #5
I've never actually used my PTO when it was this cold ... so I can't confirm that is the case. I would think that if your hydraulics are flowing (regardless of temp) that the PTO should spin. It would make sense that it's a "flow" issue though. Perhaps your hydraulic filter is clogged (or even frozen)? Have you reached the 50hr service mark yet? Might be a good time to change the hydraulic filter and see if that helps.
   / PTO issue U5030 #6
I have two types of warning lights that come on EVERY time it's cold. The red transmission light ( same as the OP) and the N (neutral) indicator will flash. (I have a power shuttle)
The transmission light will go out fairly quickly (less than a minute after it's started) but the flashing N can take a while. In the manual it says to let the tractor warm up until the N light stops flashing.
If I get impatient and run the tractor before it warms up the F,N, or R light will continue to flash, but the tractor will still go. The manual says do not work the tractor hard until this stops flashing. Depending on how cold it is the red transmission light may come back on, which would turn off the PTO if it were engaged.
The tractor has always started great in the cold and this winter has not let up since November. I really believe the OP 's tractor is fine it just needs a little more warm up time.
   / PTO issue U5030
I'm hoping it's in need of more warm-up time, but 20F isn't all that cold. One of the reasons I got this tractor was for woods work in the Winter when 0 or -10 is fairly common. I need the PTO for my Farmi winch.
I'm only at 11 hours.
   / PTO issue U5030
Update, I just been out on the thing for an hour or so, rammin around my trails through the snow. Tractor was good and warm. Still no PTO.
I called the dealer, he sounded stumped and was going to call LS and see what they had to say.
   / PTO issue U5030 #9
Was out this morning on the new U5030 and had a problem. I'm still playing around with all the features and pushing all the buttons. I have my logging winch on the back for a little ballast weight. I turned on the pto switch, it turned for about 5-10 seconds then stopped and the transmission oil pressure light came on. Pto light was still on. Did it both in auto and manual mode numerous times. It was chilly this morning but not cold (20F). The tractor was running for about 15 minutes. Also, this unit does not have the pro gear lever on the left side (the 540-750-1000 range lever). There is a covered spot where it obviously goes, but no lever. Calling dealer tomorrow.
When did they start have the 3 speed PTO on the u5030 I thought that was on the P models.
   / PTO issue U5030 #10
Not sure if yours is the same but mine can be changed to turn off the PTO when the 3pt is raised, is that the case with yours? If that is a feature I would lower your winch and try again. Is the red transmission light off? Just trying to eliminate the easy stuff first.
2005 Chevrolet Impala Sedan (A56859)
2005 Chevrolet...
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
2015 Ford F-350 4x4 Pickup Truck (A54814)
2015 Ford F-350...
TICO 510 S/A SPOTTER TRUCK (A54756)
TICO 510 S/A...
Brush Cutter Mini Skid Steer Attachment (A56857)
Brush Cutter Mini...
403 (A52706)
403 (A52706)
