DIY Welding positioner
/ DIY Welding positioner #5
Pretty slick. I would think a small Ridgid pipe vise would be nicerthan the chain vise grips, but I guess it depends on what you are working on and what's available.
/ DIY Welding positioner #6
very innovative...any idea how the jack relief valve works with a peddle/foot lever?...all the ones I've seen/used have needle valves that require CW/CCW torque to open/close...
It's common on small table lifts and atv lifts.......it is a button, spring loaded from the inside of the jack base........when depressed it opens the port internally, then when released the spring closes the valve port
/ DIY Welding positioner #8
Thanks...thought it might be something like that...just never encountered one...
...I wonder if a decent quality (secretary) chair lift would suffice?
2012 Toyota Tundra SR5 Crew Cab Pickup Truck (A61573)
2012 Toyota Tundra...
Caterpillar 12H/140H/160H Motor Graders Service and Parts Manuals (A63117)
Caterpillar...
2024 DODGE RAM 2500 HEAVY DUTY PICKUP TRUCK 4x4 (A59912)
2024 DODGE RAM...
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A63688)
2023 New Holland...
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A63118)
Case Wheels for...
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
