TYN T433
/ TYN T433 #1
ddowney1975
Redding,ca
2010 Tym T433
Has anyone hade a problem with the battery tray in there T433, Welds Braking loose, also braking the ground cable to the battery????
If So how did you fix the problem
/ TYN T433 #2
Hello Mr. Downey,
I apologize you're having issues with your battery tray.
Could you possibly post a picture of the problem area's so that I can get a better idea of the weld's etc. that are causing the issues?
/ TYN T433
Sorry i'am unsure of how to do that..... Is the a e-mail address that i can send them to you ?
/ TYN T433 #5
I have a T433Cab, and this happend to me too. I looked at the welds and dont think they were actually welded, only spot welded. I bolted up two pieces of angle iron using the two open bolt holes on the front frame to hold the battery and battery tray up until i could ask the dealer to repair as it is still under warranty.
/ TYN T433 #6
Hi Sunka,
I'm sorry to hear that you're having a similar issue.
Please keep me posted as to the status of your repair after you contact your dealer.
12ft S/A Utility Trailer (A64557)
12ft S/A Utility...
2019 RAM 5500 4X4 S/A ROLLBACK TRUCK (A67148)
2019 RAM 5500 4X4...
2015 Ford Taurus Sedan (A64557)
2015 Ford Taurus...
2014 Caterpillar Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
2014 Caterpillar...
2000 FREIGHTLINER CENTURY CLASS 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2000 FREIGHTLINER...
2020 GMC AT4 CREW CAB TRUCK (A65054)
2020 GMC AT4 CREW...
