PTO Generator
/ PTO Generator #1
gks
Member
Pocono Mountains, PA
Kubota B3300SU
I am a 6 day owner of a brand new Kubota B3300SU and I'd like y'all's thoughts and advice on a PTO generator. We've been meaning to buy a generator and now that we have the tractor, a PTO generator is an option. Pros, cons, tips, etc... Please.
/ PTO Generator #2
I had a 35KW PTO generator when we were farming. Pro: it's an awful handy piece of equipment to have around for remote repair work and welding, construction, and standby power. Con: It ties up a tractor to power it. I never liked leaving mine unattended, even when we were using it to complete barn chores and run the feeding and ventilation equipment. You also need to run it periodically to keep the windings operable and internals moisture-free. We ran ours every 3-4 months for something like running an elevator or auger at a remote location, just to keep it ready to use. A friend didn't use his for a year, and it would not generate electricity during an outage when he needed it. I would be hesitant to tie up a brand new Kubota doing what an air-cooled engine would do for much less replacement cost. We used ours on a 35HP tractor over lunch once to run the block heater on one of our larger tractors. The tractor sprung a coolant line leak, and thanks to an observant neighbor, we were able to shut it down before we lost an engine. It may be, once you price a stand alone unit against a PTO unit to fit your needs, a self-contained unit may not be that much more money.
/ PTO Generator #3
How many KW do you need and what are you willing to spend?
/ PTO Generator
I not sure what our power needs are. It seems (and makes sense) that one can buy more power for a given amount of $ with a PTO generator. 12,500 watts can be bought for about $1300. A stand alone with the same power would be easily 3 times that.
/ PTO Generator #5
Yes it would, I like 1800 rpm diesels, thats what I would go with but it depends on how much you plan to use it.
/ PTO Generator #6
I have a 10kw PTO generator and have only used it seriously during one three day outage. It has sat for at least a couple of years without generating and worked perfectly when needed. During the outage I only ran it for about an hour in the morning and an hour in the evening to let the fridge and freezer catch up and run the pumps. And the coffee maker in the morning:D. Still had the use of the tractor the rest of the day for other things. Depends what your needs are but for the average person the generator wouldn't need to run all of the time so the tractor will still be available for storm cleanup or other things. If you need power all of the time a stand alone would be better for you. I like not having more engines to maintain so like the PTO version.
/ PTO Generator #7
I plan to get one myself. Got a couple stand alone gas generators now, but it's hard to find gas if the power is out. I have a big diesel tank and 3 tractors, so it makes more sense for me.
Just realize that 25hp at the PTO will probably not get the full potential from a 12.5K gen.
/ PTO Generator #8
25HP at the pto is fine for 12kw, in fact its real good.
/ PTO Generator #9
The power head my be cheaper, but the power source (tractor) is more expensive to own and to run.
/ PTO Generator #10
As I have offered, in previous threads on this subject, in an area of frequent power outages I run my house and guest apartment with a 6,500 Watt, Honda powered generator. The ability to manage load, at the transfer switch, eliminates circuits that are unnecessary and provide power to refrigeration, water pump, lights in kitchens and living areas and in my case, an electric water heater which is energized for only a couple of hours a day.
The most frequent mistake around here is to install excess capacity in a back up generator.
While I understand that needs may vary, electric heat for instance, or need to air condition during outages, most outages, even here are of short duration which makes shedding non-critical loads painless. Every few years we get a long duration outage but in those times it seems like reduced power availability is the least of our problems.
Would I like to have an 1,800 rpm diesel 12 KW genset? Well yes but I have better uses for the $12,000 it would take to own one. Each to his own but I am trying to be the voice that says a 6,500 watt gasoline generator with a dependable engine, is just fine.
/ PTO Generator #11
GKS,
You don't say where you live, but your avatar photo looks like it has snow in the background. We live in the mountains of western North Carolina, and I'd not even consider a PTO generator as our standby source. Most of our outages occur during storms - exactly the time I don't what to have to slug through the snow to the barn, unhook whatever is mounted on the tractor, hook up the generator, get the tractor back up to the house, and wander through the snow hooking up cables. In our case our stand-alone propane-fired generator is much more to my liking.
Others obviously have different situations.
Terry
/ PTO Generator #12
I power my house with a $1200 generator, not going to tie up or wear out a $17,000 tractor to do it. L2800 w/FEL - 72" Land Pride rake
/ PTO Generator #13
I'am a PTO generator proponent I realize it has its advantages such as one less motor to maintain , farm field applications, etc. I don't care about putting pto genny run time hours on my tractor. Even if I was going to re sell it. What I don't like is leaveing tractor unattended w/pto shaft spinning. BTW I've never owned a pto powered genny.
/ PTO Generator #14
It's -10F here this am. If the power was out, I'd have the genny running. It gets cold here pretty fast, and I don't want to sit in the house all day with nothing to do. It's not cheap, but my 15kw genset is great. I have to power my well, and a electric hot water heater, those 2 take about 12Kw combined.
/ PTO Generator #15
I have a similar situation.
We heat with either coal or FHA /propane. Cooking is gas, hot water is on demand gas. The largest load is the well pump.
Our generator is a 5KW Honda. In our case 5KW is plenty of power. The only change I have considered, would be to convert the engine from gasoline to propane.
Best, Bill
/ PTO Generator #16
Factor into your decision that a lot diesel can be stored for a long time in relative safety.
When you run out of gasoline, there's a good chance that everyone else will.
Storing a lot of gasoline, safely, is problematic. Plus it has limited shelf life.
I discovered this the hard way, after a powerful storm knocked our power out for 5 days.
The power at the gas stations was out, too, so no pumps = no more gas for anybody.
I'm presently looking for a 5KW PTO unit to run with our 12 HP B5100.
/ PTO Generator #17
Stabil added to gasoline will keep it nice for up to twelve months, even in Tropical heat.
Service stations don't run out of gasoline, nor do they run out of power. They all have diesel stand-by generators, at least around here. I never store more than four five gallon containers, and that during the peak or our storm season. Other times I keep the generator tank full (and treated with Stabil) and usually have five gallons around for other gasoline equipment.
Again, please note that my comments about a smallish gasoline generator do not apply if you are set up requiring huge loads to stay warm, stay cool and cook. My cistern is my well and uses a pump and pressure tank, just like a well and I have no problem with the 3/4 HP motor on generator power while lighting the place, running my satellite tv, internet connection and refrigerator.
/ PTO Generator #18
I have a gear driven honda powered two wheel tractor. It only has one connection point, so it's easy to connect. We bought our 5500 watt PTO generator last week but we have had the tractor for a year.
My next two wheel tractor will have an air cooled diesel.
/ PTO Generator #19
Forgot the photo
/ PTO Generator #20
Sorry... User error!
Power command Transfer Switch (A62679)
Power command...
New/Unused Wolverine 72in Quick Attach Smooth Bucket (A65583)
New/Unused...
Bobcat T66 (A60462)
Bobcat T66 (A60462)
1998 International 4700 Flatbed Dump (A62613)
1998 International...
1500 Gal Stainless Steel Tank (A64127)
1500 Gal Stainless...
New/Unused Landhonor Mini Rock Grapple (A65583)
New/Unused...
