3316 shuttle
/ 3316 shuttle #1
seal oil
nfld canada
2010 mahindra 3316 shuttle tlb
I noticed when I start the engine I can hear a whissing sound . I lifted the bonnet and noticed that the fan must be touching the shroud . The fins on the fan is notched about 3/4 inch deep by 1/2 inch wide right where the shroud is . The fan does not seem to be loose . I noticed that the fins look to be closer to the shroud on the bottom than on the top . I am wondering what might be causing the fan to come in contact with the shroud causing it to cut into the fan ?
/ 3316 shuttle #3
I had the same problem only it was worse than yours by the time I discovered it. Your fan shroud bolts are probably loose and the shroud has dropped from its proper position. My dealer replaced the fan because it was quite chewed up. Evidently the final inspection fails at times.
/ 3316 shuttle
Thanks AchingBack . I will check the bolts on the fan and also the shroud bolts . When I looked at it I couldn't see any adjustment on the shroud . Looked like it is just bolted to the rad support . Maybe someone can tell me if there is any way to adjust the shroud up or down . Mine lookes to be closer on the bottom and that makes me think the shroud is a little high and that is where the fan is making contact . I could put my finger between the fan blade and the shroud on top but not on the bottom .
/ 3316 shuttle
Is anything loose or has excessive play?
I can't find anything loose . Looks like the fan is closer to the bottom of the shroud than the top . I am wondering if anyone can tell me if there is any adjustment on the shroud or rad support .
/ 3316 shuttle #6
Try loosening all of the bolts to see if the shroud will move down.
/ 3316 shuttle #8
Also check the engine and loader mounting bolts on each side, as I have seen this cause the fan to hit.
/ 3316 shuttle
Thanks . I haven't been able to check it out as I slipped on ice and fell . I can't wait to feel better and get back at the tractor . I have it parked in my garage over the pit I have to work on my truck . I am thinking I might be able to get down in the pit and look for something loose . I think the loader and engine bolts you mentioned there are 8 bolts on one side and 7 on the other side . Would that be the bolts that I should check ? Would you know what the torque for those bolts would be ?
/ 3316 shuttle #10
Your loader manual should contain a page with torque setting specifications.
/ 3316 shuttle #11
As Galen mentioned, engine rail bolts are most likely loose. They are to be checked at regular intervals. If you have notched the fan that much, they are pretty loose and you might even have one busted or missing.
Hope you get to feeling better.
/ 3316 shuttle
Thanks . A couple of the engine rail bolts were a little loose . I can't get to check the 3 bolts on the right rear because of the bracket and the pump is in the way to ge a wrench on them . The fan is touching or very close to the shroud on the bottom but I have about 3/4 of an inch on the top . Is there a way to adjust the shroud ? Could it be that the engine rail is or might be out of adjustment ?
/ 3316 shuttle #13
seal oil. I've been doing some maintenance and decided to remove my shroud so I could thoroughly blow out the back of the radiator. If your shroud is like mine, the holes in it are slotted, not round. The slots enable you to align it so there is about a finger's thickness clearance between the top of the fan blade and the inner circumference of the shroud.
Get in there with a real strong light and see what you can see. I think the dealers on here are wrong about the cause being loose engine rail bolts.
/ 3316 shuttle
My engine rail bolts were by no means falling out and probably were ok because I checked the bolts with the torque wrench 5 lbs or so lower than what was called for and it clicked . The couple that were loose just barley moved with the called for torque . The others clicked ok . The holes in the shroud do not look to be slotted . There are 3 bolts on each side of the shroud that I slackened up to see if the shroud would move but no such luck .
/ 3316 shuttle #15
Okay then. It is obvious, even though our tractors are both Mistsubishi made; there are some big differences between the 15 and 16 series. My shroud has two bolts on each side.
UNKONW  TRIAXLE ALUMINUM VACUUM TRAILER (A67714)
UNKONW TRIAXLE...
2020 GMC SIERRA 1500 (A67714)
2020 GMC SIERRA...
2009 POLAR TANK . (A67714)
2009 POLAR TANK ...
2015 CHEVROLET CAPRICE POLICE CAR (A66091)
2015 CHEVROLET...
2016 Chevrolet Colorado Crew Cab Pickup Truck (A66736)
2016 Chevrolet...
2017 Cadillac Federal 70 IN Limo - 30,529 Miles w Premium Coachwork by Federal (A63689)
2017 Cadillac...
