Oil & Fuel Adding a Spin on Racor filter to a BX25
/ Adding a Spin on Racor filter to a BX25 #71
I like the way you used your head and was able to use existing mounting bolts, Good Idea.:thumbsup:
Now you have to Wax that tractor:D
/ Adding a Spin on Racor filter to a BX25 #72
Thanks Scooby, your research motivated me to stop procrastinating & install a filter-separator worthy of these tractors. My welder is on the fritz, so I came up with a different bracket, but same location. I also thought it would be helpful to add a shut-off to simplify filter changes. Already saved me when I got a leaky bowl.
View attachment 305746 View attachment 305752 View attachment 305747 View attachment 305753 View attachment 305748
Another nice job:thumbsup:
/ Adding a Spin on Racor filter to a BX25 #73
Oh and Thank you Scooby for the advice on my stack,
A few weeks ago I followed your advice. You told me to trim it so it won't catch water. I think it looks better this way also.
Thanks:thumbsup:
Thanks! Using the existing hardware made more sense than drilling and tapping in that location, particularly if the mount was still on the tractor.
Wax... Whats that?;)
Thanks:thumbsup:
You know, its only a small detail, but I think its a bit better looking too. Looks even more factory.:thumbsup:
What was it again that you used for paint? It looks like a satin finish? Looks good though.
One last thing...
I really have to post up the the results of the last filter drain.
I dumped it into a mason jar, probably 1" total. About 1/3" maybe a bit more is water!!! Something for anyone considering this mod to think about.
/ Adding a Spin on Racor filter to a BX25 #77
I know, it's a no brainer using the existing bolts.
/ Adding a Spin on Racor filter to a BX25 #78
Maybe I missed it, but did you reuse the OEM bolts, or find longer versions due to the added mounting plate? Looking into doing a similar conversion. I like your mounting plate since I can make something similar, but don't have the equipment to make one like 4Shorts did.
Yup. OEM loader bolts.
No need for longer bolts because there is lots of stickout there to work with. Even after installing the bracket the bolts still stuck past their nuts. Just apply some red loctite to the bolts when reinstalling them.
/ Adding a Spin on Racor filter to a BX25 #80
Great, thanks. Makes it easier.
2017 Ford F-150 Ext. Cab Pickup Truck (A60352)
2017 Ford F-150...
MASSAGE CHAIR (A58214)
2016 FREIGHTLINER CASCADIA  125 6X4 T/A  DAY CAB TRUCK TRACTOR (A59906)
2016 FREIGHTLINER...
(20) 2.5cm X2M Ratchet Straps (A60463)
(20) 2.5cm X2M...
JOHN DEERE 544G WHEEL LOADER (A58214)
JOHN DEERE 544G...
2016 TAKEUCHI TB216 EXCAVATOR (A62129)
2016 TAKEUCHI...
